Author Topic: Dragon's lair help  (Read 9009 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
Dragon's lair help
« on: May 15, 2004, 12:43:16 am »
 so I'm still waiting to hear from the daphne and I would like to get this game running correctly before saturday night (big party).
DL and SA both start
mpeg test works great for both so no problems as far as not having correct video. I have all the roms and have I think I have the framefiles set right. Here's the problem both DL and SA go through the intro and when I hit start I get a coin sound the overlay comes up and then it jumps right back into the intro and freezes and I start to lose lives.
Thayer's quest, lupin 3rd, cobra command all play fine.
Here's my log if it helps.
--DAPHNE version 0.99.6
--Command line is: E:\Daphne\daphne.exe lair vldp -framefile E:\Daphne\framefile.txt -fullscreen -useoverlaysb
--CPU : AuthenticAMD 1450 MHz || Mem : 512 megs
--OS : Windows XP/.NET || Video : ALL-IN-WONDER RADEON 7500
LDV1000 : Instantaneous seeking enabled!
Set 640x480 at 16 bpp with flags: 80000001
Initializing sound system ...
Joystick #0 was successfully opened
Reading key remapping file ... (if the file is corrupt, daphne will crash, just so you know hehe)
Loading roms/lair/dl_f2_u1.bin ... 8192 bytes read into memory
Loading roms/lair/dl_f2_u2.bin ... 8192 bytes read into memory
Loading roms/lair/dl_f2_u3.bin ... 8192 bytes read into memory
Loading roms/lair/dl_f2_u4.bin ... 8192 bytes read into memory
Booting ROM ...
LDP : Since disc was stopped, we are flushing the timers (remove me later)
Play
LDP : disc is already playing, play command ignored
Play
lair : Re-allocated overlay surface (360 x 240)...
Display disable received
Search to 323 received - [25] Attract Mode, Sequence 0 Attract Mode
NOTE: converting FPS from 23.976000 to 29.970000. This may be less accurate.
Play
Search to 306 received - [25] Attract Mode, Sequence 0 Attract Mode
Search to 1424 received - [ 0] Introduction, Sequence 0
LDP-VLDP.CPP : Search failed in video or audio file
Play
Search to 1823 received - [ 0] Introduction, Sequence 3
Play
Search to 9181 received - [ b] Closing Wall, Sequence 0
Play
Search to 9301 received - [ b] Closing Wall, Sequence 4 Death Scene
Play
Search to 9965 received - [ d] Flying Horse Barding, Sequence 1 Resurrection Scene
Play
Search to 10021 received - [ d] Flying Horse Barding, Sequence 2
Play
Search to 10453 received - [ d] Flying Horse Barding, Sequence 9 Death Scene
Play
Search to 22682 received - [1f] Underground River, Sequence 1 Resurrection Scene
Play
Search to 22738 received - [1f] Underground River, Sequence 2
Play
Search to 22936 received - [1f] Underground River, Sequence 24
Play
Search to 23938 received - [1f] Underground River, Sequence 16 Death Scene
Play
Search to 4083 received - [27] Small Yellow Room, Sequence 1 Resurrection Scene
Play
Search to 1887 received - [27] Small Yellow Room, Sequence 2
Play
Freeing memory used to store audio stream...
Shutting down sound system...
Shutting down video display...
« Last Edit: May 16, 2004, 12:52:30 pm by Shieldwolf »
StephenH
Re:Dragon's lair only playing the first
« Reply #1 on: May 15, 2004, 01:26:12 am »
You may have better luck posting this on Daphne.rulecity.com board.  Daphne Devs moderate it, and they probably can help you.
btoddkelley
  • Last login:October 20, 2013, 04:52:05 pm
« Reply #2 on: May 15, 2004, 01:49:28 am »
Humor me here and turn off the overlay and try to run it. (daphne is funny about overlays and video not being at 640x480)
Todd
For it is not enough to have a good mind, rather the main thing is to apply it well.
- Descartes
Shieldwolf
  • SpearShield.com
« Reply #3 on: May 15, 2004, 11:55:57 am »
no didn't work.
Basically you hear the announcer going through the story, then when I hit start the video starts over, but the sound continues with what the narrator is saying.
btoddkelley
« Reply #4 on: May 15, 2004, 12:19:03 pm »
Do you have a dvd2daphne rip or a laserdisk rip? Also does the screen go blank and the naration continue? If so what happens if you coin up?
Todd
- Descartes
Shieldwolf
  • SpearShield.com
« Reply #5 on: May 15, 2004, 08:40:33 pm »
sorry haven't gotten back sooner.
No screen loops back to title and then either freezes on dirks face  swining sword from intro. Same for Space ace.
The funny thing is these files worked fine on my pc
btoddkelley
Re:Dragon's lair help
« Reply #6 on: May 16, 2004, 06:13:51 pm »
Does it work on the other daphne games? Also, try running the video in the mpeg seek test. Let it run and make sure it continues to play past where it gets stuck.
Todd
- Descartes
Shieldwolf
  • SpearShield.com
« Reply #7 on: May 16, 2004, 09:14:11 pm »
Sorry I thought I posted that in the 1st post. Space Ace and DL both play fine all the way through the mpeg test. so I know my video files are good. which file should i have the games pointed too?
btoddkelley
« Reply #8 on: May 16, 2004, 09:54:22 pm »
Oops. didn't re-read it.  :-[
     Your log looks ok, so the next thing I would check is the framefile. Are you launching with the daphne loader? if not, try to get it to run with the loader. Post your framefile if you would also.
Todd
- Descartes
Shieldwolf
  • SpearShield.com
« Reply #9 on: May 17, 2004, 01:32:07 am »
here's my framefile
for
DL
E:\daphne-0.99.6\dragon
151 Lair24.m2v
E:\Daphne\framefile\ace\
0  spa00.vob.m2v
I tried generating new ones as well.
Which file should I set mpeg too? I thought I had it set right but maybe not
btoddkelley
« Reply #10 on: May 17, 2004, 02:29:50 am »
That looks like part of a dvd2daphne framefile. Is this a DVD conversion? If it is a dvd2daphne conversion, the frame file is supposed to have a lot more to it. This would also explain the freeze. You only have a framefile directing you to the intro.
Todd
- Descartes
NickS
  • Last login:September 11, 2014, 06:59:58 am
« Reply #11 on: May 17, 2004, 04:06:53 am »
Todd
Yes, The framefile does seem to be the problem.
What was the source of the mpeg's?. Are they all in one large file or are they split?.
Shieldwolf
  • SpearShield.com
« Reply #12 on: May 17, 2004, 02:43:10 pm »
I have multiple mpeg files for SA and DL I also have a single
dl24 mpeg too
Here is the thing I thought that it was a bad frame file, but when I hit generate new framefile that's all it gave me.
Again all the videos are perfect. I ran the mpeg test for both games no problems.
NickS
« Reply #13 on: May 17, 2004, 03:01:11 pm »
dl24 mpeg too
It sounds like your mpeg's were extracted from a dvd.
Try adding the following instead of the "151 Lair24.m2v" line and let me know if it works. It all depends which DVD version the files were extracted from.
150   dl-slates.m2v
323   dls00.vob.m2v
1366   dls01.vob.m2v
2044   dls01d1.vob.m2v
2085   dls01d2.vob.m2v
2133   dls01d3.vob.m2v
2213   dls01b.vob.m2v
2297   dls02.vob.m2v
2729   dls02d1.vob.m2v
2801   dls02d2.vob.m2v
2849   dls02d3.vob.m2v
2921   dls02d4.vob.m2v
2956   dls02b.vob.m2v
3041   dls03.vob.m2v
3349   dls03d1.vob.m2v
3421   dls03b.vob.m2v
3505   dls04.vob.m2v
3865   dls04d1.vob.m2v
3925   dls04d2.vob.m2v
3999   dls04b.vob.m2v
4080   dls05.vob.m2v
4639   dls05d1.vob.m2v
4663   dls05d2.vob.m2v
4711   dls05d3.vob.m2v
4759   dls05d4.vob.m2v
4839   dls05d5.vob.m2v
4875   dls05d6.vob.m2v
4923   dls05d7.vob.m2v
4983   dls05b.vob.m2v
5065   dls06.vob.m2v
5423   dls06d1.vob.m2v
5459   dls06d2.vob.m2v
5495   dls06d3.vob.m2v
5543   dls06b.vob.m2v
5625   dls07.vob.m2v
5947   dls07d1.vob.m2v
6039   dls07d2.vob.m2v
6091   dls07d3.vob.m2v
6199   dls07b.vob.m2v
6281   dls08.vob.m2v
6647   dls08d1.vob.m2v
6695   dls08d2.vob.m2v
6731   dls08d3.vob.m2v
6827   dls08b.vob.m2v
6909   dls09.vob.m2v
7489   dls09d1.vob.m2v
7525   dls09d2.vob.m2v
7549   dls09d3.vob.m2v
7597   dls09d4.vob.m2v
7649   dls09d5.vob.m2v
7673   dls09d6.vob.m2v
7745   dls09b.vob.m2v
7828   dls10.vob.m2v
8395   dls10d1.vob.m2v
8449   dls10d2.vob.m2v
8533   dls10d3.vob.m2v
8569   dls10b.vob.m2v
8652   dls11.vob.m2v
8925   dls11d1.vob.m2v
9009   dls11b.vob.m2v
9091   dls12.vob.m2v
9281   dls12d1.vob.m2v
9329   dls12d2.vob.m2v
9389   dls12b.vob.m2v
9471   dls13.vob.m2v
9821   dls13d1.vob.m2v
9881   dls13b.vob.m2v
9964   dls14.vob.m2v
10453   dls14d1.vob.m2v
10501   dls14d2.vob.m2v
10565   dls14d3.vob.m2v
10601   dls14b.vob.m2v
10684   dls15.vob.m2v
11269   dls15d1.vob.m2v
11317   dls15d2.vob.m2v
11349   dls15b.vob.m2v
11432   dls16.vob.m2v
11881   dls16d1.vob.m2v
11917   dls16d2.vob.m2v
11940   dls16d3.vob.m2v
11977   dls16d4.vob.m2v
12048   dls16b.vob.m2v
12132   dls17.vob.m2v
12477   dls17d1.vob.m2v
12537   dls17d2.vob.m2v
12585   dls17b.vob.m2v
12668   dls18.vob.m2v
13029   dls18d1.vob.m2v
13089   dls18d2.vob.m2v
13163   dls18b.vob.m2v
13245   dls19.vob.m2v
13803   dls19d1.vob.m2v
13827   dls19d2.vob.m2v
13875   dls19d3.vob.m2v
13923   dls19d4.vob.m2v
14003   dls19d5.vob.m2v
14039   dls19d6.vob.m2v
14087   dls19d7.vob.m2v
14147   dls19b.vob.m2v
14229   dls20.vob.m2v
14232   dls20.vob.m2v
14575   dls20d1.vob.m2v
14611   dls20d2.vob.m2v
14659   dls20d3.vob.m2v
14707   dls20b.vob.m2v
14788   dls21.vob.m2v
15306   dls21d1.vob.m2v
15365   dls21p1.vob.m2v
15486   dls21b.vob.m2v
15569   dls22.vob.m2v
16148   dls22d1.vob.m2v
16184   dls22d2.vob.m2v
16208   dls22d3.vob.m2v
16256   dls22d4.vob.m2v
16308   dls22d5.vob.m2v
16332   dls22d6.vob.m2v
16404   dls22b.vob.m2v
16486   dls23.vob.m2v
16976   dls23d1.vob.m2v
17024   dls23d2.vob.m2v
17088   dls23d3.vob.m2v
17124   dls23b.vob.m2v
17206   dls24.vob.m2v
18036   dls24d1.vob.m2v
18060   dls24d2.vob.m2v
18142   dls24b.vob.m2v
18224   dls25.vob.m2v
18378   dls25d1.vob.m2v
18486   dls25d2.vob.m2v
18522   dls25b.vob.m2v
18605   dls26.vob.m2v
19054   dls26d1.vob.m2v
19090   dls26d2.vob.m2v
19114   dls26d3.vob.m2v
19150   dls26d4.vob.m2v
19222   dls26b.vob.m2v
19305   dls27.vob.m2v
19872   dls27d1.vob.m2v
19926   dls27d2.vob.m2v
20010   dls27d3.vob.m2v
20046   dls27b.vob.m2v
20130   dls28.vob.m2v
20384   dls28d1.vob.m2v
20450   dls28d2.vob.m2v
20486   dls28d3.vob.m2v
20534   dls28b.vob.m2v
20617   dls29.vob.m2v
20928   dls29d1.vob.m2v
21000   dls29d2.vob.m2v
21030   dls29d3.vob.m2v
21072   dls29b.vob.m2v
21155   dls30.vob.m2v
21740   dls30d1.vob.m2v
21788   dls30d2.vob.m2v
21820   dls30b.vob.m2v
21902   dls31.vob.m2v
22418   dls31d1.vob.m2v
22478   dls31p1.vob.m2v
22599   dls31b.vob.m2v
22680   dls32.vob.m2v
23938   dls32d1.vob.m2v
23962   dls32d2.vob.m2v
23986   dls32d3.vob.m2v
24010   dls32d4.vob.m2v
24034   dls32d5.vob.m2v
24094   dls32d6.vob.m2v
24158   dls32d7.vob.m2v
24238   dls32b.vob.m2v
24320   dls33.vob.m2v
25098   dls33d1.vob.m2v
25146   dls33d2.vob.m2v
25194   dls33d3.vob.m2v
25300   dls33d4.vob.m2v
25360   dls33d5.vob.m2v
25396   dls33b.vob.m2v
25479   dls34.vob.m2v
25850   dls34d1.vob.m2v
25886   dls34d2.vob.m2v
25957   dls34b.vob.m2v
26040   dls35.vob.m2v
26578   dls35d1.vob.m2v
26613   dls35d2.vob.m2v
26637   dls35b.vob.m2v
26720   dls36.vob.m2v
27050   dls36d1.vob.m2v
27085   dls36d2.vob.m2v
27122   dls36d3.vob.m2v
27158   dls36b.vob.m2v
27242   dls32.vob.m2v
28498   dls32d1.vob.m2v
28522   dls32d2.vob.m2v
28546   dls32d3.vob.m2v
28570   dls32d4.vob.m2v
28594   dls32d5.vob.m2v
28654   dls32d6.vob.m2v
28718   dls32d7.vob.m2v
28798   dls32b.vob.m2v
28880   dls38.vob.m2v
31190   dls38d1.vob.m2v
31238   dls38d2.vob.m2v
31298   dls38d3.vob.m2v
31346   dls38d4.vob.m2v
31394   dls38d5.vob.m2v
31454   dls38d6.vob.m2v
31502   dls38b.vob.m2v
Shieldwolf
  • SpearShield.com
« Reply #14 on: May 17, 2004, 03:33:47 pm »
could you do that for space ace as well. Ill try it tonight
btoddkelley
« Reply #15 on: May 17, 2004, 04:10:26 pm »
download and unzip dvd2daphne. The framefile come with it. They are the same for all conversions. That would be a easier than cutting and pasting here.
Todd
- Descartes
btoddkelley
« Reply #16 on: May 17, 2004, 04:21:10 pm »
Well, I tried to upload aan rar file with the framefile in it but the board won't allow it. PM me an email address and I will send them to you.
Todd
- Descartes
Rod1968
  • Last login:February 03, 2007, 10:19:45 pm
« Reply #17 on: May 17, 2004, 07:47:30 pm »
NICKS posted the framefile for the dvdrom version above :)
This is the framefile for the 20th anniversary dvd video version
151
« Last Edit: May 17, 2004, 07:48:26 pm by Rod1968 »
rainman
  • Newbie
  • Last login:May 30, 2004, 06:57:18 pm
« Reply #18 on: May 30, 2004, 07:15:42 pm »
Maybe someone can help me out.
I dl one zipfile containing two files :
lair24.m2v
lair24.ogg
I manually created a framefile containing :
c:\tmp\dl
151 Lair24.m2v
When I start daphne with the following options :
daphne.exe lair vldp -framefile framefile.txt
I get an error saying :
rom image file dl_f2_u1.bin could not be loaded
Please read the daphne_log.txt .........
In that logfile I see :
--Command line is: daphne.exe lair vldp -framefile framefile.txt
--CPU : GenuineIntel 2600 MHz || Mem : 512 megs
--OS : Windows XP/.NET || Video : MEDION RADEON 9600 TX
Set 640x480 at 32 bpp with flags: 0
No joysticks detected
Loading compressed ROM image dl_f2_u1.bin...file not found in .ZIP archive!
Loading roms/lair/dl_f2_u1.bin ... 0 bytes read into memory
ROM image file dl_f2_u1.bin could not be loaded
DLE readme11.txt file is missing or altered.
Please get the original readme11.txt file from www.d-l-p.com, thanks.
Could not load ROM images! You must supply these.
Can anyone help me with this ?
