Author Topic: A way to use a EYGO 19" monitor for vertical games..?  (Read 3675 times)
sirhcman@aol.com
« on: July 26, 2002, 02:12:58 am »
A way to use a EYGO 19" monitor for vertical games but leaving the monitor in horizontal mode? 320 x 240 usually cuts off the bottoms of the games..For example On Ms PacMan I cant see the last row of dots or the score I am accumulating..I am just running windows mame. Should I use a different program that might help me view these games better? 640 x 48 mode on pacman looks so small I need a magnifying glass to play..Any help is appreciated!
SNAAAKE
  • -Banned-
Re:A way to use a EYGO 19" monitor for vertical games..?
« Reply #1 on: July 26, 2002, 03:47:50 am »
okay use mame32 and leave it default..then just choose rotate screen..thats all..full screen vertical games..i have 19" eygo..so i knew how it was at the begining..
sirhcman@aol.com
« Reply #2 on: July 26, 2002, 03:41:33 pm »
Hey thanks for the help! I await in anticipation once I get the cabinet all back together and test it out! Thanks again
BTW: Are there any sites out there that give info on these eygo monitors, or any help manuals? TIA!
SNAAAKE
  • -Banned-
« Reply #3 on: July 26, 2002, 03:57:16 pm »
sorry dude..you get nothing from these monitor..i suggest dont even try to look..you will kill yourself over looking around and finding NOTHIN ;D
sirhcman@aol.com
« Reply #4 on: July 26, 2002, 06:23:06 pm »
Sounds like someone has een looking for awhile :) thanks!
SNAAAKE
  • -Banned-
« Reply #5 on: July 26, 2002, 07:40:49 pm »
heheh..damn right..before i actually bought it..i thought it would be super crappy because of what i paid..but its the best monitor ever..
sirhcman@aol.com
« Reply #6 on: July 26, 2002, 10:02:55 pm »
i bought mine off a guy on ebay for 150, i thought it was a pretty damn good deal!  ;D
SNAAAKE
  • -Banned-
« Reply #7 on: July 26, 2002, 10:14:46 pm »
way to go ;D
i paid same..i feel kinda evil..because the deal is too good to be true..i recomand to anyone however my post is totally worthless :P,because there is no problem here that we are trying to solve.
Smack
  • Last login:May 07, 2013, 11:40:41 pm
  • Who changed my avatar?
« Reply #8 on: July 30, 2002, 11:44:50 pm »
Here's the specs for the eygo 19inch that I've been going by for my advance mame setup up, hope its of some help...
Mine is rotated vertically in a cocktail cab and the games look mint. (Using Advance Mame under pure DOS)
Eygo 19" arcade monitors.
Specs:
Power Supply
Switch mode power supply
Dual AC input range
Jumper selectable
No isolation transformer required
Input Signal
Video - RGB analog, positive, 0.7 Vp-p.
Impedance - 75 ohms, terminated.
Rise Time - less than 25 nanoseconds.
Bandwidth - DC to 25 MHz (at - 3dB), mode 3.
Resolution - Model
1. 640 x 350 (70Hz refresh)
2. 640 x 400 (70Hz refresh)
3. 640 x 480 (60Hz refresh)
Sync. - TTL, positive or negative. Monitor circuitry will
automatically determine and adjust for VGA Horizontal Scan - Frequency 31.5KHz nominal
Capture range-30.5~32.5KHz
Active video - full width display of video
signals with active video from 25 to 28usec.
Linearity - plus or minus 5%
Vertical Scan - Frequency 60/70Hz
Capture range 47~85Hz
Picture Size Regulation
2%
Geometric Distortion
plus or minus 1.5% (max)
Environmental Conditions
Temperature 100 ~ 550C
Humidity 10~90%, no condensation
High Voltage
13"=23KV, 20"=25KV, with integral X-radiation
Shut-down protection
Degaussing
Automatic, operating at beginning of each power-up
cycle, provided the monitor has been turned off for
at least 20 minutes.
Never Let Donkey Kong Use Your Toilet.
(We're talkin' big processed brown bananas...)
Somebody out there stole my sig! LOL
