Author Topic: Centipede movement too slow  (Read 1026 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
« on: May 07, 2004, 09:41:58 pm »
how do you increase the speed of my track ball? It seems really slow.
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
Re:Centipede movement too slow
« Reply #1 on: May 09, 2004, 11:46:52 pm »
Try pressing "Tab" and then select the Analog settings menu, from there you can adjust the speed and sensitivity of your trackball.  I also noticed that Centitpede (REV3) seems to work best out of all the Centipede versions.
Good Luck!
Shieldwolf
  • SpearShield.com
« Reply #2 on: May 10, 2004, 12:28:57 am »
yeah revision 3 is much better
