Author Topic: Does anyone know what this game is?  (Read 1835 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: May 07, 2004, 04:31:53 pm »
I remember an arcade game that I played when at University in the UK around 1990/92 but for the hell of it I can't remember what it was called. I hope somebody here will be able to help....
let me try and describe the game play (as much as i call recall):
It was a helicopter based shoot em up.
You controlled a helicopter that was positioned centrally in the screen with a top down view on a map of various terrain (maybe in pseudo 3d). The first few levels were based at sea and around islands (i never got much further). I remember you flew around the map basically shooting military installations located on the various islands,a and also various naval type ships (there might have been also aircraft that attacked you).
I remember there was one significant and novel feature of this game:
when you turned the helicoptor using the analogue flightstick the whole map would rotate 360 degrees around the helicoptor (the helicopter remained pointing up the screen). I was really impressed with this at the time!
I think you could also control the height of the helicopter with a throttle type control type slide - i think this resulted in the map zooming in to simulate getting closer to the ground.
I would be grateful if any one knows what this game was called - it has been really bugging me for years! As far as i remember it was an awesome game to play.
Trenchbroom
  • Last login:November 21, 2020, 09:25:43 pm
  • Wampus? Get over here!
Re:Does anyone know what this game is?
« Reply #1 on: May 07, 2004, 06:43:35 pm »
Sounds like it is probably Steel Talons, by Atari:
http://www.klov.com/game_detail.php?letter=&game_id=9785
rchadd
  • Made in Cornwall
« Reply #2 on: May 07, 2004, 07:05:38 pm »
no - its not that one.
it was one player only game and had a stand up cab.
jcoleman
  • Last login:March 15, 2025, 04:12:49 pm
  • RTFM
« Reply #3 on: May 10, 2004, 02:54:19 pm »
I think you might be talking about Thunder Blade, a personal favorite based on the environmental version:
http://www.klov.com/game_detail.php?game_id=10094
Is this in MAME?  I have to check that out...
Coleman
Tailgunner
« Reply #4 on: May 10, 2004, 05:24:34 pm »
Coleman
The last auction I went to had a working enviornmental Thunder Blade. It wasn't in bad shape and went fairly cheaply.
rchadd
  • Made in Cornwall
« Reply #5 on: May 10, 2004, 09:42:46 pm »
sorry but it wasn't Thunder Blade either
think more like an arcade version of desert/soviet strike (as played on Megadrive/PS)
but the whole map rotating through 360 degrees when you try to turn the heli....
ani
  • Last login:June 17, 2004, 05:29:21 pm
« Reply #6 on: May 11, 2004, 03:41:04 pm »
Are you sure it wasn't thunderblade? If you just tried it at first, it changes. The game starts out like afterburner, then a few levels in it shifts to the overhead view.
gnateye
  • Last login:December 05, 2011, 11:22:36 am
  • 4 cabs and counting!!!
    • natty's arcade
« Reply #7 on: May 12, 2004, 10:23:53 am »
zero gunner? or zero gunner 2?
