Author Topic: Getting to the monitor with bezel in place  (Read 1516 times)
spauldingd
  • Last login:February 18, 2022, 11:41:51 am
« on: May 06, 2004, 09:59:29 am »
I finished my cabinet about a week ago and I thought I had tried all the monitor resolutions that I would use, but of course, I missed one.  My monitor is mounted behind plexiglass and is nearly impossible to get to.  I knew that going in, but I didn't think I would need to get to it.
I am able to get to the adjustment buttons if I remove my control panel and stick a long screwdriver up in there from below, but I was curious what others have done.  I almost cut a few holes in my plexi to get to the buttons, but that sheet of plexi looks so nice I hate to touch it.
Dave
SaiNRuB
  • Last login:November 26, 2024, 07:30:53 pm
  • Pluck your magic twanger, Froggy!
Re:Getting to the monitor with bezel in place
« Reply #1 on: May 06, 2004, 10:08:44 am »
What kind of cabinet do you have, most have a removeable back door to allow servicing from the back. I take it your monitor adjustment controls are mounted on the flyback our on the chassis?
Edit: Is your monitor a pc monitor also?
« Last Edit: May 06, 2004, 10:09:42 am by SaiNRuB »
spauldingd
« Reply #2 on: May 06, 2004, 01:19:45 pm »
Its just a regular PC monitor mounted in a home-made cab.
unclet
« Reply #3 on: May 06, 2004, 01:26:00 pm »
I service my arcade TV by removing the back panel and using a remote to do the "front" button stuff.   If I need to remove the TV for repair I need to remove the plexiglass and bezel and remove it from the front.
I know the remote is something you can not do, but I was just giving you a summary of what I do......
SaiNRuB
« Reply #4 on: May 06, 2004, 01:40:03 pm »
Is it in its original case our did you remove it? I ask in case your adjustment controls on your pc monitor might be removeable.
Ive seen projects where they would remove the pc monitor controls from the front bezel of the monitor and reposition them somewhere they can easily adjust the picture. I forget what project they belong to but there are several of those examples.
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
« Reply #5 on: May 06, 2004, 02:29:03 pm »
My first workings on my cab used a PC monitor, front mounted buttons like youve got, including power. With the bezel in place there was maybe 1/4" at most between the button and the bezel. I found some round adhesive velcro dots and attached em to the 'inside' of the plexi bezel so that they lined up with the respective buttons on the monitor. A little push on the plexi at the right spot and it would cause the velcro dot to connect with the button and do its thing.
Depending on the space, you may need to use like an eraser nub, or a piece of dowel rod, etc so that at rest, the button pusher is close to the button
Alternative would be to make a pinhole thru the plexi, lined up with the button, and use a toothpick or other pokey-thing to activate the button
Now though that Im using a TV, Ive got a remote. Also the tv does auto-power-on so I rarely even need the remote
If youve got a big gap between the front of the button and the back of the plexi, you could try a leaf-switch button assembly(just the round button bezel and plunger assembly) This might be cool for a power button for the monitor
