Author Topic: Arcade monitor & Advancemame  (Read 1627 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« on: May 04, 2004, 07:48:19 am »
If I am using an arcade monitor with advancemame and arcadeos under puredos, do I need to worry about what's being output to the monitor prior to arcadeos booting up? I am not using a jpac or arcadevga.
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
Re:Arcade monitor & Advancemame
« Reply #1 on: May 04, 2004, 11:31:59 am »
Yes, you certainly DO need to worry about the video output frequency before advMAME loads.
I have only played with advMAME briefly, but I think most people set it up to play a sound when it has loaded. It is then safe to turn on your monitor (assuming the advMAME video settings have been configured correctly).
It is also possible to hook a relay up the monitor and pc parellel port to turn the monitor on when it is safe to do so, but it's probably more effort than it's worth.
Acids
  • Last login:July 26, 2025, 06:10:07 am
  • Bring It.. Smart arse!
« Reply #2 on: May 10, 2004, 06:02:14 am »
To save yourself the worry of damaging your arcade monitor, i suggest you get a jpac.
Well worth the money.
Popcorrin
« Reply #3 on: May 11, 2004, 01:42:53 pm »
I have been researching this for a bit now and I think you are right Acids, the J-Pac is worth the money.  ArcadeOs does have an option of hooking up a circuit to the parralel port to turn on the monitor when it is safe but it would be more work than it is worth.  Thanks for the responses.
Acids
« Reply #4 on: May 13, 2004, 09:53:27 pm »
I went throught the same thing deciding on what i was going to do.
I tried the jpac and are amazed how AMAZING this device is...  It makes life SO much easier.
Glad i could help.
