Author Topic: Monitor gets blurry  (Read 1738 times)
tw661
  • Last login:July 23, 2004, 11:42:39 pm
Monitor gets blurry
« on: May 04, 2004, 07:38:16 am »
I have a Wells Gardner arcade monitor with WinXP.  After a little while the monitor gets blurry in WinXP or in the Mamewah front-end and just a little in the games.  Is this my refresh rate?  I put it as low as I could in the windows properties (60hz).  Also I'm using Arcade VGA.
Thanks for youre help.
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
Re:Monitor gets blurry
« Reply #1 on: May 06, 2004, 03:54:32 am »
I am by no means an expert, but check the brightness if that doesn't help you may have a bad picture tube.  Advice told to me by WG tech over the phone. I'm now exchanging mine for a new one
Ken Layton
  • Guru
  • Technician
« Reply #2 on: May 06, 2004, 10:24:42 am »
What model is the monitor?
When making any adjustments to a monitor of any type, it's alway a good idea to let the monitor warm up and stabilize at least 10 minutes before performing any adjustments. Could be something as simple as tweaking the brightness/contrast/screen/focus controls.
If you have a K7000 monitor and you get a big drift in focus you probably have a failing flyback transformer.
