Author Topic: Making a Marquee from a .jpg ???  (Read 3367 times)
AGGIEZ
  • Last login:January 30, 2017, 05:59:50 pm
« on: May 03, 2004, 04:10:31 pm »
Need some help. I found some great Alex Ross artwork that I'd like to convert into a marquee. Any ideas on what would be the easiest way to convert the top blue section of this artwork into a marquee for my cab (Captain Americade)?? I don't want to just stretch it to fit and print it, losing all the resolution. All ideas are appreciated!
« Last Edit: May 03, 2004, 04:40:26 pm by AGGIEZ »
mahuti
Re:Making a Marquee from a .jpg ???
« Reply #1 on: May 03, 2004, 06:25:00 pm »
Find the original source, scan it.
You can't upres an image without losing resolution. There are  a few tricks to 'fake it' but you can't do what you are asking. From a technical standpoint it is not possible... you can't make something with nothing. If you have 72 dots per inch, and you scale up 200%, youre dots per inch will then be 36. That's the way it works.
If you do a search, I've detailed several times on this board how best to 'fake' the dpi when you upres something.
AGGIEZ
« Reply #2 on: May 03, 2004, 11:35:23 pm »
So, can I print out this .jpg in it's original size and scan that? Once it's scanned, how do I get it to be 27.5 x 7 without it looking like a bunch of los res squares? I was thinking about buying this poster and going down in size from the poster. The poster is about 24 x 36 with the blue section that I'd need being about 24 x 12. Who knows, maybe I should just go with something else...
mahuti
« Reply #3 on: May 04, 2004, 10:39:18 am »
No. Original Source... You have to go to wherever that JPG came from... a magazine, a book, a comic, an art print, and scan that. A  book or a print might have enough DPI for you to get what you really want, the other two... maybe, it just depends.
You mention that there's a poster. That's really what you should go after. Scan that, and it would make a much better source than a low-res JPG.
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #4 on: May 06, 2004, 06:42:03 am »
Why can't he print that at its current resolution and then scan it at a really high resolution if he wants to blow it up? The stock pictutre looks clear enough at the current resolution.
Lets say he wanted it 3 times bigger. If he scanned it at 900 dots per inch and blew it up 3 times bigger wouldn't it still be at 300 dots per inch?
If you build a frankenpanel, chances are I don't care for you as a person.
mahuti
« Reply #5 on: May 06, 2004, 10:17:38 am »
If you print a picture at 72 DPI, and then scan it at 900 DPI, it still EFFECTIVELY has a resolution of 72 DPI. See DOTS per inch... If you print out 72 DOTS per inch, and then scan those dots in, you create a really detailed scan of a bunch of dots packed in, 72 to the inch. If you want to do that, you just skip the printing & scanning, and just upres it in Photoshop. It doesn't help you either way, you don't increase resolution.  Newspapers are about 35-65 dpi. If you scanned in a pic in a newspaper at 300 dpi, it would still look like a pic from a newspaper.
Another bad thing, you might create is a moir
AGGIEZ
« Reply #6 on: May 06, 2004, 10:47:00 am »
flampoo
  • Last login:March 20, 2014, 11:41:07 am
  • BYObsession
    • flampoo
« Reply #7 on: May 06, 2004, 11:07:47 am »
Why don't you just use the poster for the marquee? It's 24" wide? That should be about right. Then all you'll be paying for is the side art.
AGGIEZ
« Reply #8 on: May 06, 2004, 03:01:21 pm »
Yeh, the width is good, but the length isn't. The section I want to use is probably 10-12" long and I need a marquee that is 24" x 7". I'd have to cut off alot of the art and I'm not sure I want to do that. We'll see when I get the poster.
Brax
« Reply #9 on: May 07, 2004, 12:27:08 pm »
mahuti
« Reply #10 on: May 07, 2004, 12:53:49 pm »
You don't need to print it and scan it to do that. Just upres it in an application
mahuti
« Reply #11 on: May 07, 2004, 12:56:32 pm »
OH, and you wouldn't get a bigger picture at the same (effective) resolution. You would get a bigger picture at a lower resolution. When you upres 72 dpi (or print and scan) to 3 times it's size, you would get a resolution of approximately 24 DPI.
