Author Topic: mamewah list error  (Read 2054 times)
btoddkelley
  • Last login:October 20, 2013, 04:52:05 pm
mamewah list error
« on: May 01, 2004, 10:15:44 am »
I updated mame to 81 (using anlog mame and mamwah) and when i try to generate a new list i get runtime error 62. This only happens when using rom folder vs list info. Works fine when using rom folder only.(but you don't get the full names) I deleted all of the files in mamewahs file folder, started over and it still happens. (I did put the cfgs back after i figured out that it still wouldn't work).
Any thoughts?
Todd
For it is not enough to have a good mind, rather the main thing is to apply it well.
- Descartes
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re:mamewah list error
« Reply #1 on: May 01, 2004, 04:18:32 pm »
Any thoughts?
Todd
Are you sure the path and filename of your mame executable is set correctly in your EMU*.cfg file?
/steve
btoddkelley
« Reply #2 on: May 01, 2004, 05:32:04 pm »
I can play games from the list. I just cannot generate a list with the full names of the games. (rom folder vs list info). Generate the list fine with "rom folder only".
todd
- Descartes
btoddkelley
« Reply #3 on: May 04, 2004, 12:04:26 am »
The problem is with analog mame. When I use regular mame it works fine. Any thoughts on why software guru's?
Todd
- Descartes
moloch
  • Last login:June 29, 2022, 06:22:19 pm
  • I'm an ill'llama!
« Reply #4 on: May 18, 2004, 12:36:01 am »
I have tried to use Mamewah on two separate machines and I keep getting the same error:
Run-time error
« Reply #5 on: May 18, 2004, 04:43:33 am »
BTodd: are you running Win98?
I wonder if this is a '98 specific problem, possibly related to another error (usually Run Time 75)...I posted a fix for that one which might work...hold on while I try to find it...
« Reply #6 on: May 18, 2004, 04:47:58 am »
OK try this:
Make a batch file which does something like (substitute your mame path etc.):
c:
cd\mame
mame > temp
exit
Then run the batch file *before* MAMEWAH for the first time after boot-up.
If it doesn't work 1st time, delete the contents of the \Files folder, reboot and try again.  Please let me know how it goes...
btoddkelley
« Reply #7 on: May 18, 2004, 10:51:45 am »
I am using XP. I concluded it was a problem with  analog mame in my case. Once i switched to regular mame it worked fine. When a new Analog mame is released I will try it again.
Todd
- Descartes
« Reply #8 on: May 18, 2004, 12:05:45 pm »
That's pretty odd.  I take it Analog MAME's -listinfo (& other 'standard' switches) work the same as regular MAME?
moloch
  • I'm an ill'llama!
« Reply #9 on: May 18, 2004, 01:57:51 pm »
I was just going to edit my autoexec.bat to start mamewah. I do not know how to just make a batch file. I am guessing that I just make a ".bat" file out of notepad with your instructions and have autoexec.bat call it during boot.
I saw mamewah running on an old machine at my work and I now know what it should look like, and I never got it to run on either of the two machines that I have tried. I just got a blank white screen.
« Reply #10 on: May 18, 2004, 06:34:04 pm »
Yes a batch file is just a text file with .bat as the extension.  If you're using Windows to make it make sure it doesn't do that stupid hide the extension thing - you could end up with mamewah.bat.txt...
Don't call it in autoexec.bat, unless I am mistaken I think that only works until Windows boots.  Add the batch file to your Windows Startup folder instead.
btoddkelley
« Reply #11 on: May 18, 2004, 06:37:20 pm »
I don't know if they do or not. I had only used analog mame a couple times before. It worked in .79. Before mamewah I was (I hate to admit) a Mame32 guy.
Todd
- Descartes
moloch
  • I'm an ill'llama!
« Reply #12 on: May 20, 2004, 11:57:40 am »
I finally had time to work on my mame machine last night. I got Mamewah to work by deleting all of the files in the files directory. I did not try the batch file trick, because I finally got it to work.
