Author Topic: go7 help please  (Read 1373 times)
dirt
  • Last login:October 30, 2024, 08:36:38 pm
go7 help please
« on: April 24, 2004, 05:21:12 pm »
is there any known problems using a g07 montior with an arcadevga card? the reason i ask is because i had my computer hooked up to my pole position cab with a wg monitor and everything works perfect. i have 2 g07 monitors and they both roll and look a little scrambled when i hook them up and adjusting the chassis doesn't seem to help them out. when i hook them up to my jamma cab they work perfect, no rolling or anything. any help would be great.
dirt
WANTED: NINTENDO CABINETS WORKING OR NOT
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re:go7 help please
« Reply #1 on: April 24, 2004, 08:09:56 pm »
Do you have the sync plugged in the same connector as the rgb?
It goes into the one above it.
I used seperate syncs on mine.
If you are using the video amp do the following.
The following copied from utilmarc website.
Almost all monitors, even those which have separate V and H sync inputs, will work with composite sync (generally connected to the H input) A few monitors may need separate H and V sync though. In this case the syncs can be separated by doing the following:
Identify the location on the PCB marked "CUT for H/V"
Cut through the short section of track between the two "half-moon" shapes.
Connect the monitor vertical sync to the connection (white terminal block) marked SYNC
Connect the monitor horizontal sync to the connection (white terminal block) which is unmarked
Later,
dabone
dirt
Re:go7 help please
« Reply #2 on: April 24, 2004, 08:26:21 pm »
thanks for the info i will try that right now. btw where on the ultimarc site did you get that from? i thought i read everything in the arcadevga section before i posted, i guess i missed it somehow :-[
dirt
dirt
Re:go7 help please
« Reply #3 on: April 24, 2004, 08:42:18 pm »
that was it!!!! thanks again for the info. ;D ;D ;D
dirt
dabone
  • Time to work...
Re:go7 help please
« Reply #4 on: April 25, 2004, 08:40:47 am »
