Author Topic: How to fix horizontal position on an Arcade Monitor  (Read 4312 times)
tw661
  • Last login:July 23, 2004, 11:42:39 pm
« on: April 23, 2004, 08:01:30 am »
Hi.  Just completed my first Mame cabinet.  And the horizontal position is off just a little to the right by about 1/4 of an inch.  How do I move this to the left just a tad?  This would me easy if I used a PC monitor, but not sure if there are similar controls that control the horizontal and vertical position on arcade monitors.
menace
Re:How to fix horizontal position on an Arcade Monitor
« Reply #1 on: April 23, 2004, 08:20:21 am »
Whats the monitor and whats the setup?  Typically there are pots that control this positioning.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: April 23, 2004, 11:59:49 am »
And the make and model of the monitor is.....?????
tw661
« Reply #3 on: April 23, 2004, 04:38:10 pm »
I don't know the exact model of the monitor.  I see a sku number that has wgec on it so I'm guessing it mght be a Wells Garner arcade monitor.  My setup is monitor to jamma connector to  JPAC to VideoVGA card.  I hope this is enought info.
tw661
« Reply #4 on: May 03, 2004, 05:50:58 pm »
What's a pots?
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
« Reply #5 on: May 04, 2004, 07:13:33 am »
A pot is a variable resistor, like the volume control on your stereo.
You should have various pots such as h. phase, h. freq, v. shift, etc.
They can have slightly different names between makes and models, but you want to adjust the horizontal shift (h. shift) to move it left and right. h. amp will increase the width.
tw661
« Reply #6 on: May 04, 2004, 07:39:35 am »
Thanks I'll look around for my pots tonight.
