Author Topic: How to protect custom side art?  (Read 2783 times)
flampoo
  • Last login:March 20, 2014, 11:41:07 am
  • BYObsession
    • flampoo
« on: April 19, 2004, 02:52:27 pm »
I just printed off some custom sideart for a cab I'm building. I used a plotter and printed on heavyweight matte paper. After I cut and spray the back of the art with adhesive paper then mount it to the arcade, what's the best (and cheapest) solution for sealing/protecting the artwork? I don't want to bother with lamination.
Suggestions?
spystyle
Re:How to protect custom side art?
« Reply #1 on: May 16, 2004, 01:29:36 am »
This is total overkill but you could ...
Build your cabinet side panels out of 5/8" material, then lay down the art, then cover it entirely with 1/8" acrylic, and use 3/4" t-molding (5/8" + 1/8" = 3/4")
This would protect your side art forever, and the sides of your cabinet would be shiny and smooth.
I think that would look so cool !
Dig it?
Craig
« Last Edit: December 09, 2006, 11:49:20 am by spystyle »
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #2 on: May 16, 2004, 02:58:16 pm »
You can use this clear acrylic spray or something similar.  I think there are some other brands around as well.
http://www.papilio.com/spray%20clear%20acrylic%20wood%20metal%20crafts%20aerosol.html
Next I'll be on fries, and that's when the big money starts rolling in.
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
« Reply #3 on: May 18, 2004, 09:40:02 am »
I used a liquid acrylic that I rolled on with a paint roller type thing.  I started with the spray, but I found it to dry pretty uneven (I was trying to cover a large area) and was very thin for my liking.  I did about 3 coats of the liquid acrylic (can get it at any art supply store).  Not as solid as 1/8th inch acrylic panel as someone else suggested, but I think it is pretty good.
:) Rotate or die! :)
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #4 on: May 18, 2004, 09:43:55 am »
I used a roll of clear self adhesive plastic to cover the print.
dvdapex
  • Last login:August 21, 2006, 05:16:42 pm
« Reply #5 on: June 16, 2004, 09:05:09 am »
Does liquid acrylic saturate paper?  For example: if I wanted to put a poster on my cabinet as side art, could I cover it with liquid acrylic without it warping the poster or messing it up like other liquids would?
big_garryb
  • Last login:June 09, 2006, 08:08:12 am
« Reply #6 on: June 20, 2004, 06:56:17 pm »
i am doing as Spystyle said - covering all with lexan....... im sticking a couple of bolts through to hold it - also means it will be fairly easy tochange the artwork if i wanna.!!!
garryb
oh dear - not rain again......Scottish weather is crap, oh well - at least Mame can keep me company.
