Author Topic: Which OS...  (Read 7033 times)
Truz
  • Last login:February 23, 2009, 12:03:01 pm
Re:Which OS...
« Reply #40 on: April 22, 2004, 10:32:49 am »
my roms are fine, i think that maybe it cant find them on my computer. I pointed the xmamerc.dist to where my rom folder is so i dont know what the problem is.
SirPeale
  • Green Mountain Man
Re:Which OS...
« Reply #41 on: April 22, 2004, 11:48:33 am »
He forgot to state the path.
$xmame.x11 dkong -rp /path/to/your/roms
You have to state the -rp (or -rompath) or it won't work.
Also, check your .xmamerc file in /$HOME/.xmame to see if the ROM path is stated there.
Truz
Re:Which OS...
« Reply #42 on: April 22, 2004, 11:53:50 am »
ok i scrapped everything an decided to start over from step one. I encounter a problem once again when trying to copy over the xmamerc.dist over to the home/.xmame directory. The .xmame folder shows up in the home dir as an invisible folder first of all.... is it supposed to be like that.
Anyway i encountered someone online who seems to be having the same problem as i did, here check it out.
http://www.beemulated.net/phorum/read.php?f=1&i=286&t=286
He says that xmame was looking for the xmamrc.dist file in the home/xmame directory. So he just copied the file over, and it worked. This is my problem, the file will not copy over. I dont know why. I run the cp command in a terminal and copy the file over and it seems as if it copied over as no errors were reported. Granted it told me there was no such file a few times but i think they were just typo errors.
So basically right now i think i have the same problem as this guy did, but i cannot for the life of me get the xmamerc.dist to copy to the /home/.xmame folder. I dont get what the problem is and why it just wont transfer over when i run the copy command.
SirPeale
Re:Which OS...
« Reply #43 on: April 22, 2004, 12:07:59 pm »
all folders (or files) that begin with "." are invisible.  You can see them with this:
$ ls -a
or if you want to just display your hidden files:
$ ls .* -a
Did you try what I suggested before you scrapped it?
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
Re:Which OS...
« Reply #44 on: April 22, 2004, 12:19:50 pm »
Are you sure that you renamed xmamerc properly?
I have never done anything with the xmamerc.dist file before, so I tried it out just now.  Here's what I did:
1) I copied xmamerc.dist from my src directory to "/home/jstookey/.xmame":
  $cd downloads/src/xmame-0.81.1
  $cp xmamerc.dist ~/.xmame/
2) I renamed it to "xmamerc":
  $cd /home/jstookey/.xmame/
  $mv xmamerc.dist xmamerc
3) Edited the rompath line in xmamerc:
rompath                 /home/jstookey/downloads/emu/roms
4) run xmame
  $cd /home/jstookey/downloads/src/xmame-0.81.1/
  $./xmame.x11 dkong
SirPeale
Re:Which OS...
« Reply #45 on: April 22, 2004, 12:43:38 pm »
The first time I ran xmame, it created both the dir .xmame and .xmame/xmamerc for me.  Using generic options, of course, to be edited by the user.
Truz
Re:Which OS...
« Reply #46 on: April 22, 2004, 01:18:03 pm »
hahahah yes!!! triumph. I got it thanks guys, i followed what jerry said in his last post and it worked. tried out a couple more roms and they worked as well. Woohooo! You guys rock
But one quick question, how do i get it to go full screen all the games run i really tiny windows, how do i fix that?
My next task will be getting a frontend going like advancemenu or gxmame... hope i dont have as much trouble with that.
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
Re:Which OS...
« Reply #47 on: April 22, 2004, 01:28:00 pm »
Press ctrl-alt-end while playing in a window to go into full-screen mode.
Or, you can set the following value in xmamerc:
x11-mode                3
