Author Topic: Turn off monitor when PC shutsdown  (Read 7335 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: April 19, 2004, 07:17:40 am »
I would like to be able to automatically turn off the power to my arcade monitor whenever my PC is shutdown.
I am using an ATX PSU.
Is this possible?
JasonF
  • Last login:June 08, 2005, 08:37:35 am
  • "Jason F" on RGVAC!
Re:Turn off monitor when PC shutsdown
« Reply #1 on: April 19, 2004, 09:42:45 am »
There is a type of power strip that can tell based on the current draw of one "control" outlet when your device is on or off (you would plug your ATX power supply into this outlet).  When off, it switches off other outlets (and likewise, switches them on when the control outlet begins to draw enough current).
You might be able to find something like this at Fry's, CompUSA, etc.  I did a quick search, and this looks like what I'm describing:
http://www.bitsltd.net/smartstrip/landing1/landing.htm
[I have no affiliation and do not endorse the linked product--provided as an example only]
rchadd
  • Made in Cornwall
« Reply #2 on: April 19, 2004, 10:14:41 am »
yes, this looks very interesting.
I thought the ATX PSU is powered all the time - even when PC has been shutdown. Suppose it doesn't draw so much current then and so that triggers the other outlets to be shut off.
i am in UK so will investigate if possible to get similar here.
not sure if feasible to get it shipped from US if can't find UK equivalent ( we have 240v power system).
any electrically minded people here think it is possible to implement similar from scratch? know of a circuit design that will do this?
could i modify a regular belkin 4 way power block (with builtin filter) to do this?
cheers
- richard
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #3 on: April 19, 2004, 12:05:51 pm »
maplin's do an equivalent in the UK - think it goes for around
rchadd
  • Made in Cornwall
Build one myself?
« Reply #4 on: April 19, 2004, 01:03:46 pm »
yes you are correct, it is on www.maplin.co.uk website.
It is called the "Intelligent Mains Extension Lead" and available for
« Last Edit: April 19, 2004, 01:06:41 pm by rchadd »
Teknique
  • Last login:October 02, 2015, 10:35:46 am
  • I'm a Gauntlet wizard in real life
« Reply #5 on: April 19, 2004, 02:49:23 pm »
take a look at this too:
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00924031000
I know some ppl use this for their cabs.
Your screen name has been added to my frag list.
JasonF
« Reply #6 on: April 19, 2004, 04:18:34 pm »
To roll your own, you could tap into the 5VDC or 12VDC outputs of the ATX power supply, and then find a relay that will switch your AC in response to the DC.  I don't have any example relays to provide, but you would need to consider the maximum voltage that the relay will handle as well as the maximum current draw.  You could use multiple relays to power different things (i.e., one for a monitor, one for the marquee light, etc) if the current rating is not high enough for all of your devices.
rchadd
  • Made in Cornwall
« Reply #7 on: April 19, 2004, 05:22:08 pm »
I have received a suggestion for a relay based solution (see attached pic) - thanks Gary!
here is the spec of the relay used:
http://www.maplin.co.uk/products/module.asp?moduleno=2516
product code YX97F
price 1.49 + VAT
Ultra Miniature High Power Mains Relay
An ultra-miniature relay capable of switching 10A resistive at 240Vac. The relay is fully enclosed and is designed for direct printed circuit mounting. Available with a single-pole changeover silver cadmium oxide contact. Dimensions: 22 x 17
« Last Edit: April 19, 2004, 05:24:16 pm by rchadd »
JasonF
« Reply #8 on: April 20, 2004, 06:59:26 am »
Yes, neutral would not be switched through the relay.  This is consistant with how light switches in your home are wired.
KevSteele
  • Last login:January 20, 2025, 11:29:37 am
  • Retrogaming Media Mogul in Rehab
« Reply #9 on: April 22, 2004, 10:13:51 am »
I'll endorse it - the SmartStrip is a great power strip for MAME cabs - I've got a review on my site:
http://www.retroblast.com/reviews/smartstrip1.html
I'm actually working right now on a review of their 2nd-generation SmartStrip, with an adjustable trigger point for activating. They've also got time-delayed versions.
Kevin
Kevin Steele, Former Editor and Publisher of RetroBlast! and GameRoom Magazine
rchadd
  • Made in Cornwall
« Reply #10 on: April 22, 2004, 11:11:04 am »
it might be good - but no use if you live outside the US  ::)
In UK we are 240v
KevSteele
« Reply #11 on: April 22, 2004, 01:29:01 pm »
In UK we are 240v
You Brits always do things the hard way, don't you? Drive on the wrong side of the road, force people to wire up their own power plugs, use 240v, the metric system...why can't you do it right like us?  ;)
(Um, did I get that "irony" thing right?)
Kevin
rchadd
  • Made in Cornwall
« Reply #12 on: April 22, 2004, 04:10:45 pm »
yep you got it (irony that is) :)
in fact most people here don't want the metric system either.
a while ago a fruit and veg market trader was taken to court because he would only sell his produce in pounds and ounces. it was highly publicised but resistance is futile. the metric stuff was forced on us by "europe".
bring back feet and inches!!!
KevSteele
« Reply #13 on: April 22, 2004, 07:31:13 pm »
Funny thing is, I was educated in the metric system, part of a short-lived push in the seventies to switch America over to the metric system. It fizzled out (inertia wins again!), so I'm a metric-loving American trapped in a land of sixteenths of an inch and however many damn feet in a mile...
Everything divisable by 10, gotta love it...sigh...
