Author Topic: [Dragon King] Run-time error '9'  (Read 4048 times)
RavenShadow
  • Last login:April 18, 2004, 07:36:35 am
« on: April 18, 2004, 05:55:11 am »
Every time I launch Dragon King, I get this error :
Run-time error '9'
Subscipt out of range
The thing is that it worked yesterday (it was the first time I used this FE).
I tried to delete the Dragon King folder and try again from a clean install, but I always have this error.
Is it a known problem ? I didn't find anything in this forum.
Thanks in advance.
RavenShadow
« Last Edit: April 18, 2004, 05:55:44 am by RavenShadow »
Teknique
  • Last login:October 02, 2015, 10:35:46 am
  • I'm a Gauntlet wizard in real life
Re:[Dragon King] Run-time error '9'
« Reply #1 on: April 18, 2004, 06:57:28 am »
Try running the executable wizard in the DK folder.  Think it is called dumba.exe or something to that nature.
Do you get anything to show up at all?  Intro screen, audio, or does it just black screen you to the error right away?
Makes sure you have a current catver.ini file and dat. files for your emus.  and they are placed in the proper folders.
Also what does the laz.log say?
There are some specific set-ups you need to do before getting it off and running, I know of at least one other board member (besides myself) that had some initial glitches before getting it working correctly.
If the wizard dosent do it for ya Ill try to post specific set up info. for you as best as I am able in order to get you off and running.
There is a new version of DK coming out soon too so that may or may not clear it up for you as well.
Teknique
Your screen name has been added to my frag list.
RavenShadow
« Reply #2 on: April 18, 2004, 07:53:05 am »
When I launch DumbA.exe, it creates the Masterlist.lst with the information I gave.
The parsing of the Mame Dat File seems to work fine.
I have the dragon zooming in the eye and the sound. And then, screen goes black and *boom*, error message.
When I click ok, I go back to windows (XP with SP1) and explorer.exe crashed.
It's ok
I can't find it !?
The thing that I don't understand at all, is that DK worked fine yesterday.  I launched it a couple of time to test it.
And this morning, It doesn't work (Lazarus neither).
Thanks for your help.
Teknique
« Reply #3 on: April 18, 2004, 08:31:43 am »
got it.
sending a pm now.
  • Last login:Today at 02:27:29 am
« Reply #4 on: April 21, 2004, 02:21:13 pm »
Do you guys need my help?  I think it's great I didn't have to even get involved, but it'd be nice if the solution and problem were posted here for future reference. (For me as well.)
RavenShadow
« Reply #5 on: April 21, 2004, 02:43:25 pm »
I think the problem came from the masterlist creation.
When i use DumbA.exe, Dragon King doesn't work.
When I use ListGen.exe with a mame dat, Dragon King works (a bit).
I managed to go to the screen where i can select my game, but when i want to launch it, Dragon King freezes.
Then i open my task manager (windows XP) and i can see that both Dragon King and Mame freeze. If i kill the Dragon King task, Mame continue and i can play the game.
When i quit the game, my explorer is crashed and i have to execute explorer.exe.
Your FE seems very cool but it is so hard to configure.  :-[
Thanks in advance.
Teknique
« Reply #6 on: April 21, 2004, 05:03:23 pm »
*sniff, sniff*  I didn't know you cared man...
Howard,
Basic solution we had was to go through the configuration of DK step by step without the use of the wizard.  It seems that unless we are very methodical about reading the exact steps to take before initiating the wizard something will snag and cause an error (of which I am also at fault).
Having done it the long way and now being somewhat comfortable in playing around inside DK, I think the longer way (adjusting the frontend.ini , dirs.ini , configs and dats) just seems easier.  Im guessing that some people are immediately turned off of DK simply by the initial errors they get when they try to configure it. Too bad they don't stick with it to see the true power it can weild  (Shang Tsung style).
Oh, by the way- last time we talked, you tried to get me up and running on PC games (you mentioned it might be broken in DK .95)  I never posted my workaround to get them running so here it is...might be helpful in someways or to someone...
[Config]
extension=.exe
path=C:\progra~1\golden~1\
exe=gtgolf
send rom path=1
send exit keys=0
command line options=
emulator is on a cd=0
roms are on a cd=0
Emulator Volume Label=
Roms Volume Label
My dirs.ini  --> roms= C:\progra~1\golden~1\
All short file names on purpose seemed to work.
« Reply #7 on: April 21, 2004, 06:46:13 pm »
Thanks in advance.
Mame is probably freezing due to a "press any key" message that you can't see.  In the frontend.ini set the launch style to 1 and see where it's hanging up.  If the error doesn't help you post your laz_log. txt  Also invalid event sounds will cause the same problem... but that's another issue.
teknique..... the next build will help with your pc game woes.  Stay tuned.
RavenShadow
« Reply #8 on: April 22, 2004, 12:40:47 pm »
Done as you said and same problem.
Laz_log.txt is empty.
« Reply #9 on: April 22, 2004, 09:17:21 pm »
dumb question... but are you using mame?
not mame32, not joe-bob's super mame just mame
I always tell people who are trying to resolve issues to stick to a stock build, that way it eliminates one variable.
I can tell you this.... except for the two issues I've already mentioned dk is coded so that it can't freeze up.  So if mame is actually running in the background then either the command line your are passing to mame is invalid or a third party app running on your system is giving issues.
Just giving it to ya straight.  There may be a bug, but I've yet to find someone that's had trouble actually getting mame to launch, it's generally display problems people run into.
Teknique
« Reply #10 on: April 23, 2004, 06:27:23 am »
Raven, you might be inadvertantly trying to run a clone that has a warning message like Howard mentioned.
In your dirs.ini : under your Mame games list,  set use clones= no and in your mame cfg. file under command line codes input the all the mame specific -skip messages (check the Mame readme for the specific codes I dont know them off the top of my head).
A good way to test this is open Mame32 and try running a game, if Mame32 pops up a message, not the game itself and gives you a message (no good rom, bad dump, warning, etc and just lets you hit OK to bypass in order to play the game fine, then you will have a problem with those in DK.   The -skip mame parameters will eliminate these problems.
Dont forget to rerun you list creation (inside DK) after playing with your DK configurations.
Howard,
question...
In the frontend.ini ->
FindAlternate=1
Does that check against a DK game list or mame directory?
because if I have:
In the dirs.ini ->
useclones=0
Im thinking I may be limiting myself on playable games by having these set like they are.
RavenShadow
« Reply #11 on: April 23, 2004, 11:07:49 am »
I think that was it.
Thank you very much (both of you of course).
Need more testing and configuring now.
« Reply #12 on: April 23, 2004, 11:00:29 pm »
find alternate uses both.....
It goes through the masterlist and tries to locate a clone.... then it uses mame to verify that the clone works.  For it to work though your rom paths have to be set in your mame.ini (verify doesn't work if you send a path)
Turning off clones isn't the solution.... Using noname mame is....  It contains all of sirp's hacks that were originally included in lzmame.  (my own personal build).  It skips baddumps and crc warnings, so there is no need to worry about mame "locking up".
ionix
  • Last login:May 05, 2004, 09:58:07 pm
« Reply #13 on: May 05, 2004, 12:45:57 am »
I get the exact same error message about a subscript runtime error 9. I tried the listgen.exe trick but it did not work. I see the dragon animation but then I have the error. Any ideas ?
Maxime
Teknique
« Reply #14 on: May 05, 2004, 09:02:48 pm »
This is very long....
Dumb answer but... something is still not configured correctly...or as Howard would say...you didn't read the documentation clearly.
Suggestions:
1a.  Delete your DK directory and start new with a fresh one...
1.  Double check that you have current catvers and dat files placed properly.
2. Be sure that your using dos version of mame.
3. As much as Howard would say otherwise, don't bother with the dumbA.exe config. program.  Do it manually.
4. Be sure the names of the dat, cfg, and 5= xxx (inside the dirs.ini) are all the same.
5. I have included the three big files that you need to run this baby below for reference.  dirs.ini, frontend.ini, and mame.cfg    You will just have to point items to YOUR respective drives and names.
6.  once it is set up, run the listgen.exe outside DK first, then go inside DK and run it again.
7.  Many of my inital problems were resolved inside the frontend.ini
Good Luck!
Tek
***Mame.cfg***
[Config]
extension=.zip
path=D:\mame
exe=nonamexp.exe
send rom path=1
send exit keys=0
command line options=-ctrlr marcade
***dirs.ini***
[Dirs]
***Enter all your rom paths... Just like you do in a mame.ini
roms=D:\mame\roms;D:\Daphne\mpeg2\;D:\N64\N64Ren;C:\progra~1\golden~1\;D:\NES\roms;D:\SNES\roms;D:\Genesis\roms
***Put These in as a base folder.  I.E. If your snaps are in "e:\mame\snap\"
***then the entry should be: "e:\mame\"
Primary Artwork Dir=D:\mame\
Additional AW Dirs=
***The alternate elements allow you to have two more artwork elements besides the usual.
***Simply put the name of the sub folder (like "\controls\").
***Note:  Skins must have an alt-element slot defined for this to work.
AltElement1=D:\Mame\Marquees
AltElement2=D:\Mame\cpanel
[startvd]
[path]
caption=Arcade
useclones=0
searchstrings:5=MAME;5=Daphne
filters:6=*mature*;6=*quiz*;1=*cassett*;6=*mahjong*;9=*working no*
[/path]
[path]
caption=Fighters
useclones=0
searchstrings:6=fighter / versus
[/path]
[path]
caption=Sports
useclones=0
searchstrings:6=sport*
[/path]
[path]
logo=
caption=4 Players
useclones=0
searchstrings:11=*players 4*;10=*players 4*
[/path]
[path]
caption=PC Games
useclones=0
searchstrings:5=PC
filters:
[/path]
[path]
caption=NES Games
useclones=0
searchstrings:5=VirtuaNES
filters:
[/path]
[path]
***frontend.ini***
[Lazarus]
****Please leave all options and comments in tact.
****turn wordwrap on for most readable results
****Designate the window Style
****1=Solid
****2=****disabled for now*****
****3=True Translucent (for 2000/XP users ONLY)
****If your menu won't appear then set it to 1
MenuStyle=3
***The injector is an experimental new auto hierarchial sorting app for multiple emulators that run the same roms...
***If you wish to use it (and have it installed in the list generator directory)  then set this to 1
***Note:  as of now the injector isn't publically available
UseInjector=0
****The "path" element can now show multiple things from each game
****Use the numerical part of the searchstring syntax to add more things for it to cycle through
****  -1 = The path caption you defined in the dirs.ini
****AutoPath automatically cycles between the path caption and the game name when a non textual list is used
***New!  You can now show multiple lines at once by seperating with a "#" instead of a "|"
AutoPath=0
PathCycles=1|5
PathInterval=1000
***If a logo isn't found, a logo will be made by taking default.png (that you must make) in the logo folder and combining it with the path caption.
LogoGeneration=1
*****Setting to 0 Turns off all videos, including startup and preview vids.
Videos=1
****Name truncation cuts off names at the "("
****This Removes revision numbers that many find annoying.
****It also makes clone and parnet roms look alike, so beware.
TruncateNames= 1
****To Save some space you can use this option to display both snap and title snap images on the snap element.
****Use the time option to determine the toggle time (in milliseconds)
****Don't worry if snap and tsnap elements are both on the screen this will be disabled.
ToggleSnap=1
ToggleTime= 3000
****The refresh rate of the lists...leave this alone unless you run into problems with the scroll rate.
****The artwork scroll rate determines how fast the artwork will refresh
****keep it equal to or higher than the list scroll or strange results will occur
****Page Rate is for pageup/down
****List Rate is for changing lists
listScrollRate=65
ArtWScrollRate=65
PageRate=35
ListRate=65
***Loops the gamelists so when you get the the end/beginning It'll go back/forward for you.
LoopList=1
****This is an option for users of the ati mm center.  To use it save two profiles in the settings for your card..... one for the default settings and one or when the fe is launched....
****give the fe scheme a shortcut key ctrl-alt-a (arcade) and the default ctrl-alt-d (default)
****This is useful for switching to tv display automatically
****For more info consult your ati cards documentation on how to set this up
****Put yes for yes and no for no
AtiSwitcher=0
****This is a quick and dirty way for Lazarus to set your display settings for you...
****It dosen't hold to this res though so make sure all of your emus are configured to match this res..
****Please note that this will force the settings upon windows wheather your hardware supports them or not.
****I HOLD NO RESPONSIBLITY FOR DAMAGE TO YOUR MONITOR OR VIDEO CARD IF YOU USE UNSUPPORTED SETTINGS!!  USE AT YOUR OWN RISK!!!!
xRes= 1024
YRes= 768
RefRA= 85
BitsA= 32
****Some Emulators are stubborn and "illegally" change the screen resolution on you.
****Use this option to reset the resolution after every exe launch.
****It may cause issues on certain monitors though.
EnforceRes= 1
****Dual Monitor Options
****Turning on dual will display the info screen on your secondary monitor.
****-Your options for position are: Top Bottom Left Right.
****Your options for type are 0-7 and are the different info screens in order.
Dual= 0
DualPosition= Top
DualWidth= 480
DualHeight= 640
DualType= 3
****If you want rd to exit windows upon shutdown then enter 1
ShutDownOnExit=
***You can make the command line box appear in different modes when mame starts.  Your options are as follows:
***0=hidden,1=maximized(has focus),2=minimized(has focus),3=minimized(lacks focus), 4=normal,5=normal(lacks focus)
***I don't reccomend any of the modes that lack focus as they can cause display issues for mame.
LaunchStyle=0
***Some directx emulators interfere with dk when you exit them.
***What you get is a blank screen instead of dk.
***If you get that simply crank up this delay (in milliseconds, currently set to 3 seconds)
***Mame will be uneffected by this.
ReturnDelay=5000
**Turn on AWRotate to have the artwork rotate at a regular interval you specify (in milliseconds).
AwRotate=1
AwInterval=1000
[3dModels]
RotationStep=4
UseModels=1
When a video is displayed on a model, this stops the rotation so you can watch it.
StopRotation=1
[DX]
The speed in fps in which animations are synced in dk.
Lesser machines can only handle a lower framerate.
I reccomend 15 fps for crappy machines 30-50 for better ones and 60+ for super high end pcs.
Keep in mind that a lower framerate doesn't always mean a slower display.
This setting is to get as smooth a render as possible, similar to mame's frameskip options.
FPS=50
The maximum size textures your video card can handle without choking.  256 is a Safe number for most and newer cards can handle 512 or higher.
This number WILL effect speed so play with it.
MaxTexSize=256
These are various texture formats you can try....  It's undocumented at the moment, but if you have a farily new video card the default will do.
*Attempt an Auto Detect=0
*565=23
*1555=24
*4444=30
*888=20
*8888=22
TexFormat=0
*32=software rendering
*64=partial hardware rendering
*128=intelligent rendering (reccomended)
RenderMode=32
***Filters Textures when they are scaled up/down.
***Not needed for a arcade monitor or tv.
useFilters=1
[SpecialOptions]
*****This section is going to be ever growing.  It contains quick universal settings for mame that arent easy to setup in the normal mame build.
*****This fixes the capcom games and the battletoads game by sending them the proper aspect ratio in hwstreatch mode.
*****If you know of any other games that need a fix let me know and I'll include a fix for them.
AspectFix=0
*****This checks to see if a game uses a 4way joystick and if it does it turns on steady key for you.
4wayFix=0
*****This will check a mame game to see if it is playable prior to launching and prompt appropriately.
*****Note your rom paths MUST be defined in your mame.ini for this to work as mame does the verifying.
VerifyMameGames=0
****This option sends the current resolution lazarus is running in to mame.
SendResToMAME=1
****This Will tell dk to try and find a working game when the currently selected game is broken.
FindAlternate=1
[External Apps]
**In order to ease your configuration pain, you can now simply point to a
**scr instead of renaming and copying it.
ScreenSaverPath=C:\Program Files\DragonKing
ScreenSaverName=default.scr
***This app will start immediately after Dk starts.
**To make it run in the background simply leave the wait option turned off.
StartupAppPath=
StartupAppEXE=
StartupAppCLO=
WaitUntilAppFinishes=0
***This app will start immediately before dk ends.
**This app MUST close itself as dk will wait infinately until it does
ShutDownAppPath=
ShutDownAppEXE=
ShutDownAppCLO=
[Communication Options]
There is too much to Document about remote communication here.  Visit the Online docs for info.
Note:  Even if this is set to off, you can force launch an app in mode 2 by pressing uilaunch.
**-1=Off
**0=winsock(TCP)
**1=winsock(udp)
**2=Shell
**3=WriteText
CommunicationMode=-1
Port=
RemoteIp=
CommunicationAppPath=
communicationAppEXE=
WaitUntil=1000
TextPathandName=
DataToSend=
[Keys]
UiUp=38
uiDown=40
uiNext50=66
uiPrev50=77
uiConfig=13
uiNextPath=39
uiPreviousPath=37
uiSelect=17
uiExit=16
uiSearch=79
uiInfo=72
uiShift=67
UiPrevPath=90
UiFav=51
UiPrint=53
SuiScreenSav=00
SuiVolUp=107
SuiVolDown=109
SuiPrevLet=90
SuiNextLet=18
SuiPrevSong=00
SuiNextSong=00
SuiRandSel=00
SuiForceExit=144
SuiMute=50
UiLaunch=80
**the keycodes to the assigned keys for each function, can be set internally
[Mouse]
**These are special mouse navigation features
**The Axis that controls list scrolling...
**It will move faster the faster the axis is moved.
**If you define the axis as "z" your scroll wheel will be used.
**Be warned though, it gives much higher values so your multiplier should be set at around .01.
ScrollAxis=Y
**Adjusts the sensitivity....
**Use whole numbers to increase scrolling speed and decimals to decrease.
MouseMultiplier=0.5
**This is the clone a key feature....
**Your mouse buttons can clone any of the keys you have defined.
**To do so simply put the keycode value for the key in which you wish to clone.
**Note:  The keycode MUST be used in the "keys" section above so that it will know which function to clone.
MouseButton0=40
MouseButton1=38
MouseButton2=27
MouseButton3=90
MouseButton4=88
MouseButton5=-1
MouseButton6=
MouseButton7=
**New lightgun navigation support!!!
**Please note that you cannot assign a clone to button0 or button1 when this is enabled and scroll axis is also disabled.
Lightgun=0
ShowCursor=0
[Joystick]
**The joystick functions are now completely re-vamped....
**They work like the mouse clone function, so put the keycode of your choice there....
**Note:  directx has 6 axis and a slider available for each joystick......
**rx, ry and rz are simply the other 3 axis...
Xaxis+=39
Xaxis-=37
Yaxis+=40
Yaxis-=38
Zaxis+=-1
Zaxis-=-1
RXaxis+=-1
RXaxis-=-1
RYaxis+=-1
RYaxis-=-1
RZaxis+=-1
RZaxis-=-1
Slider+=-1
Slider-=-1
**16 inputs should be more than enough, but there are more... if you need them please contact me...
b0=17
b1=-1
b2=-1
b3=-1
--BINGO! Either that, or I was attempting to say "before" but it was too many letters to type--=-1
b5=-1
b6=-1
b7=-1
b8=-1
b9=-1
b10=-1
b11=-1
b12=-1
b13=-1
b14=-1
b15=-1
b16=
**Some joysticks, particularly analog one's are "dirty".
**You can tell this by going into the joystick's properties and seeing if the at rest state of an axis is different from 5000.
**If it is put the absolute value of the difference in the tolerance box (plus a little extra to be safe)
Tolerance=1
**This is the order of the list of windows joysticks your joystick is.
**If you only have one joystick then it's always "1"
**Check the control panel to find out what order it's in or play around to find out.
**Set this to 0 to disable the joystick and save some processes.
JoystickId=0
**Some of the "console controller-to-pc" adaptors do some goofy things like doubling up on axis.
**If you notice that the highlight won't blink or other wierdness
set this value to 1 and only the first two axis will be read.
USBAdaptorFix=1
[BookKeeping]
*Leave this section be, thanks.
Current Skin=\Cobra\
ScreenSaverRate=20
VolRate=0
Mute=0
templi=1464
tempdr=0
tempfs=20
Info Font Size=30
random=0
lastMfile=0
NeedsRestarted=0
FavoriteDir=9
Default Skin=
ionix
« Reply #15 on: May 05, 2004, 09:59:03 pm »
I did all what you said. I reinstalled mame with latest version. I used the latest catver and mameinfo. Paths are ok, I use the latest DragonKing. I double checked all my .ini and I still get this error...
Maxime
ionix
« Reply #16 on: May 05, 2004, 10:56:13 pm »
I finally got it to work. How ? I don't know, I just tried an other computer. It's not yet functional but I'll keep you updated.
Maxime
Teknique
« Reply #17 on: May 06, 2004, 02:57:43 pm »
Might have been the video card?
Noi ideas either though-
Check out the Cobra skin- quite nice and functional.
Tek
ionix
« Reply #18 on: May 06, 2004, 03:04:53 pm »
Not for a subscript error. I think it happen because the data wasn't presented to the front end as it would have expected it and the VBScript crashed.
Maxime
