Author Topic: Easy Marquee Request  (Read 11783 times)
SirPeale
  • Green Mountain Man
« on: April 16, 2004, 10:44:47 am »
Need a marquee for a cab I'm working on.  I'd like to use that character explosion background, with 'ARCADE CLASSICS' (all caps) as the text.  Nice and simple, like to see some examples of fonts for this.  The size of the marquee is 23.75" x 7.5"
drunkatuw
  • Last login:April 24, 2025, 02:25:30 pm
    • Drunk at UW.com
Re:Easy Marquee Request
« Reply #1 on: April 17, 2004, 10:48:19 pm »
Peale,
Check your PM.
« Last Edit: April 18, 2004, 10:44:38 am by drunkatuw »
maraxle
« Reply #2 on: April 18, 2004, 10:17:47 am »
Gunship is a good font that's all caps.
There's also a ton of free fonts here.
SirPeale
« Reply #3 on: April 18, 2004, 05:49:01 pm »
Very sweet!  I have to go to Kinkos now!
How about one that replaces the 'C's with Pac-Man?
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #4 on: April 18, 2004, 06:12:18 pm »
Here's one I've been playing around with. I got the font from www.blambot.com , he sells very professional comic-style fonts and has a collection of free ones too.
SirPeale
« Reply #5 on: April 18, 2004, 06:42:29 pm »
Man!  That rocks!  Can you make the font in a bluish to match the background colors?
JoyMonkey
    • JoyMonkey.com
« Reply #6 on: April 18, 2004, 06:58:25 pm »
Tadaaaah!
JoyMonkey
    • JoyMonkey.com
« Reply #7 on: April 18, 2004, 07:15:31 pm »
and again...
JoyMonkey
    • JoyMonkey.com
« Reply #8 on: April 18, 2004, 08:15:16 pm »
not so sure about this one...
SirPeale
« Reply #9 on: April 18, 2004, 08:46:23 pm »
Heck, no!  You hit it on the head with this one:
Edit: didnt' realize there were two stuck together.  I was referring to the one on the bottom.
Where can I get the original from?
And thanks to everyone that has been helping me with this!  Of course, everyone is welcome to use the marquee if it suits you.
« Last Edit: April 18, 2004, 08:58:01 pm by Peale »
Goz
  • KOTA
« Reply #10 on: April 18, 2004, 08:53:56 pm »
Damn.. It never ceases to amaze me the talent / artistic ability some of the members of this group have.
I might want to use that for one of my projects as well.
-Goz
Daniel270
  • Last login:April 10, 2011, 12:34:14 pm
  • Older Than PONG!!!
« Reply #11 on: April 18, 2004, 09:05:47 pm »
Any way I can get a full size printable of the two?  I really like the style!!
Daniel
I Haven't Lost My Mind, It's Backed Up On Disk Somewhere.
drunkatuw
    • Drunk at UW.com
« Reply #12 on: April 18, 2004, 09:07:18 pm »
JoyMonkey...I love the font and the look of those marquees.  I'd also like to know where I could get the original (full size) copy of the last marquee.  I agree with Peale, I like the blue letters the best.
JoyMonkey
    • JoyMonkey.com
« Reply #13 on: April 18, 2004, 09:40:33 pm »
I'll set up a web page with all the marquees I did today available at full size (600dpi).
Should be up in a little while at:
http://mame.joymonkey.com/marquees
EDIT: the last three marquees are now available at the web-page mentioned above.
If anyone decides to use them, please let me know how the finished product turns out.
« Last Edit: April 18, 2004, 10:42:53 pm by JoyMonkey »
froggerman
  • Last login:March 01, 2015, 03:23:14 am
  • You want how many buttons?!
« Reply #14 on: April 19, 2004, 12:53:59 am »
JoyMonkey, I love what you did with the font on this marquee. Great stuff.
drunkatuw
    • Drunk at UW.com
« Reply #15 on: April 22, 2004, 02:54:25 pm »
JoyMonkey,
Any chance you would be able to share the photoshop or illustrator (whatever you created the file in) file or give step by step instructions on how you modified that font to look so good?  I'd like to use this marquee (or similar) but have matching side art, so I'd need to be able to reproduce the same effect.
Thanks,
drunkatuw
JoyMonkey
    • JoyMonkey.com
« Reply #16 on: April 22, 2004, 05:45:49 pm »
JoyMonkey,
Thanks,
drunkatuw
I used CorelDraw to make the lettering (I used to hate Corel with a passion, but was forced into it at work and now it's all I use for vector work, I find it a lot easier and faster than Illustrator).
I used PhotoShop to scale and crop Rom's background to the right size and then imported it into Corel.
Here's a PDF detailing how I did the lettering. You can achieve the same effect using Illustrator just as easy, but my brain no longer thinks in Illustrator. Hopefully it makes some sense.
darktemp
  • Last login:July 20, 2006, 11:18:39 pm
  • Rumbler
« Reply #17 on: April 22, 2004, 10:32:05 pm »
JoyMonkey,
Thanks,
drunkatuw
I'll second that request.  I followed your instructions and got to step 5 and I'm lost.  Your marquees look great, I would love to use one of yours but I want to personalize the text and background.
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #18 on: April 23, 2004, 12:33:52 am »
Alright!  A fellow Coreldrawer guy.
In step 5:
     Converting the Outline (stroke) to an object is the last option in the Arrange dropdown (Ctrl+Shift+Q).
     You should noticed that there are now three outlines of everything in Wireframe mode.  The outer and inner comprise the outline and the inner the original lettering.  (Outlines grow from the original border in and out - whereas Contour just grows outward or just inward)
     Taking the letter "D" as an example, choose one of the middle wireframes of the outside of the letter, hold shift and choose the middle wireframe of the inside of the letter.  It should say 2 Objects Selected on Layer 1 down in the bottom.
     In the Arrange dropdown, pick Combine (or rightclick on the object then Combine).  Now the letter D is solid again.  Meaning it will show the hole in the center when colored.
To easily move object in front of and behind each other I find it easier to use Shift+PgUp or +PgDn to move them all the way to the front or back.  Ctrl+PgUp or +PgDn to move them front and back one step at a time.
Next I'll be on fries, and that's when the big money starts rolling in.
drunkatuw
    • Drunk at UW.com
« Reply #19 on: April 25, 2004, 09:37:13 pm »
I just thought I'd throw some ideas out there for those using photoshop instead of corel draw.  I've managed to get my marquee to look very similar to JoyMonkey's (except for the pacman font 'C').
Steps:
1. Use the given whoopass font that joymonkey linked to above.
2. You need to do this each letter individual in photoshop (gets kind of repetative).
3. Use font tool to create 'A' (pick your own size (I used around 230pt).
4.  Layer-> Layer Stlye -> Stroke...
5.  stroke size around 40px
6.  Fill type gradient (I got the exact colors of joymonkey's font bye using the eye drop tool (very handy!)
7.  Layer -> Layer Style -> gradient overlay (again use the eye drop tool too match colors or pick your own).
8.  Layer -> Layer Style -> Inner shadow.  Angle around 45, size around 40px, left all other settings at default.
9.  Play around with layer transform (ctrl+T) to adjust size of all letters and move layers around to put correct layers on top
below is an in-progress jpg.  Let me know if it looks ok.
Edit:  I just found out that you can copy layer styles by going to Layer-> Layer Style-> copy layer style and then select the new layer and go to Layer-> Layer Style-> paste layer style and then repeat for each layer, you only need to copy once though.  Made it go rather quickly for me.
« Last Edit: April 25, 2004, 09:54:54 pm by drunkatuw »
drunkatuw
    • Drunk at UW.com
« Reply #20 on: April 25, 2004, 10:25:55 pm »
I tweaked the process above by adding a inner and outer glow to create a black outline of the "stroke" to create a better edge between the different letters similar to joymonkey's.  Here is what I have right now (almost final).
Sprucemoose
  • Last login:March 23, 2009, 03:56:10 pm
  • You Spent How Much?!
« Reply #21 on: April 26, 2004, 10:11:24 am »
Like the artwork, but my opinion is that the light source should be the same for both the artwork and lettering.  In your case the light is coming from behind the lettering in the middle and the shade might look better that way.  Again, just my preference.
Good luck
MameMe
  • Last login:June 08, 2005, 06:45:25 am
« Reply #22 on: May 04, 2004, 04:58:04 pm »
Can you post the original version without the lettering?  I wouldn't mid using it on my CP.
Thanks :D
mahuti
« Reply #23 on: May 04, 2004, 08:09:41 pm »
MameMe
« Reply #24 on: May 04, 2004, 08:48:27 pm »
Thank you Peale!  I hope to use this as a CP overlay.
SirPeale
« Reply #25 on: May 04, 2004, 09:19:45 pm »
Heh...that was Mahuti
MameMe
« Reply #26 on: May 04, 2004, 09:39:48 pm »
Oh yea..lol Thanks Mahuti
SirPeale
« Reply #27 on: May 24, 2004, 12:01:52 pm »
Man, I'm ticked.  I took the image to the sign printer for him to do.  I told him exactly what it was for, and how it would be mounted.  He said it would take him a week.
A week came and went.  I called (on a Saturday AM) and left a message wondering where it was.
Then I went on vacation.
I got back, and the first thing I did was check phone messages.  Only one, from the guy, saying that my marquee was ready.  The message was left on a Friday, two weeks after I dropped it off, and a week after he said it would be done.
I drag the kids down the shop, only to find he made a sticky backed sign.  It looks great, no doubt, but he printed it forwards, and it needs to be printed BACKWARDS!  Something that was made very clear.
So now I have to wait - AGAIN - for this to be printed.  Says it'll take another week.
It's a good thing this isn't the final piece of the puzzle.
AGGIEZ
  • Last login:January 30, 2017, 05:59:50 pm
« Reply #28 on: May 24, 2004, 06:42:45 pm »
Peale, can you put the marquee with the blue font on localarcade.com???
SirPeale
« Reply #29 on: May 24, 2004, 10:20:07 pm »
Yah, I can do that.
AGGIEZ
« Reply #30 on: May 24, 2004, 11:07:41 pm »
JoyMonkey
    • JoyMonkey.com
« Reply #31 on: May 24, 2004, 11:24:46 pm »
Ooh. I really should put all those marquees I did on localarcade. They're available on my site here:
http://mame.joymonkey.com/marquees/
but they're eating up my bandwidth.
AGGIEZ
« Reply #32 on: May 25, 2004, 01:21:09 pm »
DEFINITELY put the red ones on there JoyMonkey!!
SirPeale
« Reply #33 on: May 25, 2004, 03:29:08 pm »
Two of them are on there now.
SirPeale
« Reply #34 on: May 29, 2004, 11:48:40 pm »
Here's a follow-up request: side art.  Side art that looks like this marquee.  So it matches the cabinet.
JoyMonkey
    • JoyMonkey.com
« Reply #35 on: May 30, 2004, 08:43:40 pm »
Hows about something like this. All thanks again to Rom's magnificent 'Fusion' artwork.
SirPeale
« Reply #36 on: May 31, 2004, 11:44:26 am »
Make the text not close together and in the yellow/orange combo, and I think a winner is you!
JoyMonkey
    • JoyMonkey.com
« Reply #37 on: May 31, 2004, 11:55:49 am »
Like this?
SirPeale
« Reply #38 on: May 31, 2004, 12:30:07 pm »
Im assuming the text is tilted for a reason.  I dunno...just doesn't look right to me.  Probably because the tilt is so slight.
Of course once it's mounted it could be turned in any direction.  But yeah, that looks good.
JoyMonkey
    • JoyMonkey.com
« Reply #39 on: May 31, 2004, 08:16:58 pm »
I thought the words needed a little rotation, seeing as every little octagonal piece is flying out at a different angle it gives it a sense of movement with the pieces.
But then again, this isn't going on my cab...
« Last Edit: May 31, 2004, 08:17:31 pm by JoyMonkey »
