Author Topic: Is Tron broken in Mame32.v74?  (Read 1965 times)
unclet
« on: April 15, 2004, 06:55:27 pm »
Had a bunch of people come over to play on the cabinet and started up Tron only to find out it hangs right a the beginning of play.
Anyone have this problem?    Can I update to Mame.v075?  If so, would I need to update all of my CHD files to use the new format ..... I really do not want to do all of that again...
Generic Eric
Re:Is Tron broken in Mame32.v74?
« Reply #1 on: April 15, 2004, 09:57:34 pm »
Yes, you can update to .75, even up to .81 not sure if that will fix the problem.  I don't play tron and my computer went south, so I don't even have mame completely set up...
No info on mametesters.com about it
Might get more of a response in the software forum
nighthawk2099
  • Last login:June 10, 2015, 04:01:16 pm
  • I LIKE TATER-TOTS!
    • IRONMAME
« Reply #2 on: April 16, 2004, 07:41:31 am »
 ;D  -  Yep run fine in .81
unclet
« Reply #3 on: April 16, 2004, 09:21:49 am »
Do I need to upgrade my current CHD files (which I use for V.74) to use the new CHD format if I upgrade to V.81
If so, is there a conversion tool which helps me do this rather easily, or must I redownload all game images?
Kane
  • Last login:June 06, 2023, 08:05:47 am
  • What?
« Reply #4 on: April 16, 2004, 01:50:06 pm »
For version 0.78 and above, the CHD format was changed, and any CHD files that were being used in versions 0.77 and below need to be updated.
To do this, you will need the "chdman" tool, which replaces the now defunct "hdcomp" tool. The chdman.exe file comes with the standard MAME binary zip file which you can find at http://www.mame.net/downmain.html.
Before doing any updating, make backups of the CHDs if you can, should anything go wrong when the updating takes place.
For most of the chd's you simply need to convert them with chdman. As an example, we will look at the steps to convert the chd file for "Killer Instinct" which is "kinst.chd". (This assumes you have placed the chd file to convert in the same directory as the chdman tool.
First, rename the file "kinst.chd" to "kinstold.chd"
Use chdman to update the chd by using the command "chdman -update kinstold.chd kinst.chd" This will generate a new updated "kinst.chd" file in the same directory.
Check the new file has been created in the directory, and then delete the old version, "kinstold.chd".
Finally, move the new updated file back to its correct place, the "kinst" directory, if you moved it from there to carry out the update.
« Last Edit: April 16, 2004, 02:10:42 pm by Kane »
