Author Topic: mess, mamewah and bat files  (Read 3065 times)
btoddkelley
  • Last login:October 20, 2013, 04:52:05 pm
« on: April 13, 2004, 04:14:31 pm »
I am trying to set up mamewah to use mess for coleco and Atari 7800 games and I have made a foolish mistake.
Here is my bat file for coleco:
start /wait C:\Emulators\mess\mess.exe a7800 -cart %1
exit
And atari 7800:
exit
When i try to start a game  a box opens and closes very quickly and I am back to the game select screen.
Any idea where my mistake is in the dat files?
Todd
For it is not enough to have a good mind, rather the main thing is to apply it well.
- Descartes
Re:mess, mamewah and bat files
« Reply #1 on: April 13, 2004, 06:25:07 pm »
Firstly your commandlines are both the same ;)  I guess that's just a mistake in your post but could cause problems if you're trying to load a coleco rom with a7800 hardware...
Set Show DOS Box to Yes, and right-click the batch files' properties and uncheck 'Close on Exit'.  Then when you try to launch a game the DOS box which pops up should remain visible so you can read what it says...
btoddkelley
« Reply #2 on: April 13, 2004, 11:18:12 pm »
Yea the first bat file reads:
start /wait C:\Emulators\mess\mess.exe coleco -cart %1
exit
I do not have a "close on exit" tab when I right click on properties. I have a general and compatability tab. niether contain that box. Am I looking in the wrong place???
Todd
- Descartes
« Reply #3 on: April 14, 2004, 06:17:16 am »
exit
No my mistake I think, maybe you only get the 'Close on Exit' tickbox for DOS programs and not batch files  :-\
OK Another thing you could check is the debug.log file (in the MAMEWAH folder).  It is re-written each time you launch a game - you should be able to use it to identify what is wrong with the commandline MAMEWAH is using...
btoddkelley
« Reply #4 on: April 14, 2004, 11:11:02 pm »
The log just shows what I thought was the correct command line and the rom name. I am starting to think the problem is with mess. The version I downloaded includes the mess gui. I cannot seem to find a version that does not have the gui. Does the gui version not work with mame wah?
Todd
- Descartes
« Reply #5 on: April 15, 2004, 07:25:22 am »
I don't know, I don't use MESS personally...
Try running the commandline string from debug.log from a command prompt to see what happens.  I believe you can get the normal commandline version from http://www.mess.org/download.html
btoddkelley
« Reply #6 on: April 15, 2004, 08:58:09 pm »
Thanks for your help min. I got it working by creating a new config file.
Todd
- Descartes
