Okay, so, to be as simplistic as possible about it:
Stunt Cycle is not available in MAME because it wouldn't actually NEED MAME if emulated.
well, i was originally commenting on peales comment about it not using roms and  thus couldnt be emulated. true, he may have meant it cannot be emulated in mame. on its own im saying that comment probably isnt true.
however, if we talk about mame again (which i wasnt originally) then maybe stunt cycle COULD run on mame...
without knowing about how mame actually works i cant know myself if this is true. i would have imagined any motherboard could (technically speaking) be emulated within the framework. ok, so stunt cycles motherboard doesnt have an actual cpu. i dont know if within mame, it HAS to have a cpu, ram, clock etc emulated. dragons lair is emulated but of course it wont work in mame because there is no laser disk. if the framework is quite loose on what kind of motherboard can be emulated then i dont see why (theoretically as opposed to morally) the stunt cycle motherboard could be emulated. there are still roms for stunt cycle. true they are for graphics only as opposed to game code, but i cant imagine there is some 'dungeons and dragons' kinda rule that says (in deep scary voice) "thou shalt not have a rom unless it contains game code!" and also "ye shalt not have a motherboard that also is the game"
like i say, i dont know how mame is put together. does it consist of an invariable number of 'lego' pieces the difference of which is only speed and number of pieces (like cpu- how many, how fast, clock-what speed, ram-size etc) or is each piece crafted exactly after the original motherboard maybe with some pre-designed pieces ready to go (like the ubiquitous z80 processor). to me its just one sort of piece of electronics compared to another. surely all the electronics of say 'scramble' are emulated- any caps, resistors, transistors etc would need to be 'there'. so the stunt cycle would just happen to not have a cpu and happen to have many more transistors, caps and resistors...
i dunno. poor paige must be getting annoyed at seeing his old thread staying up here. he probably doesnt even have the cab anymore! i might post this question in a different section.
edit: wasn't pong in one of the earliest versions of mame?
