Author Topic: Flipping the windows display?  (Read 1698 times)
tep0583
  • Last login:October 26, 2009, 05:00:51 pm
« on: April 08, 2004, 08:29:15 am »
I'm finishing up my first cab, which is an older mirror-style cab. The problem I'm running into is that the display is upside-down, if I put the TV in there in the position that it fits best. Even if I rotate it, the display will be correct vertically, but reverced horizontially. I can correct this in-game through MAME, but not in the game-selection screen of Mamewah. The newer versions of Nvidia's drivers do allow me to rotate the screen, but this will only fix one axis.
Basically, I'm wondering if anyone knows of a way to correct this through Windows, so I don't have to use the flip y command when starting games and so the game list is easier to read.
PacManFan
  • Last login:December 06, 2005, 12:18:56 pm
    • Kymaera Home Page
Re:Flipping the windows display?
« Reply #1 on: April 08, 2004, 09:13:31 am »
I don't think you'll find a software solution to do this, you need to modify the TV to do this, It's not that hard.
The easiest way to do this is to switch the wires going to your Monitor's tube. There are 4 wires,  yellow/green , and blue/ red, I think you need to switch them to be green/yellow , red/ blue. This will reverse the directions of the horizontal and vertical scans, and make the image appear correct in the mirror.
-PMF
All Hail Smezznar! The Giant purple centipede of Omnicron 5. Regail him with your odiferous offerings of onion powder!
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« Reply #2 on: April 08, 2004, 05:06:16 pm »
To my knowledge, ArcadeOs will flip and reverse the menu, just in case you don't want to change your tv wiring.
tep0583
« Reply #3 on: April 08, 2004, 08:23:12 pm »
-PMF
I know the wires you're talking about. I'll take a look to see if that looks like a viable solution.
Thanks.
tep0583
« Reply #4 on: April 08, 2004, 08:24:09 pm »
I'll take a look at Arcade OS also. Might be easier than moding the TV....
Thanks.
crashwg
« Reply #5 on: April 08, 2004, 09:48:28 pm »
FWIW, the switching of the wires in the tv isn't hard at all and it's completely reversable.  I've done it a couple times on tv's attempting to make one of those 144" projection tv kits you always see on ebay :P  What a waste of time!  The projection thing that is, not the switching of the wires...
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
tep0583
« Reply #6 on: April 10, 2004, 03:40:56 am »
You guys are awesome!
Switching the green/yellow pair worked like a charm! Took me all of about five minutes to do and it works great.
Thanks to all for the replies.
