Author Topic: Where to find glass clips/retainers for cocktail cab ?  (Read 2096 times)
Cornholio72
« on: July 18, 2002, 04:24:33 am »
I am almost finished with my cocktail cabinet, but just need a couple more things.  The hardest thing I can't find is the glass clps that are used to hold the glass to the wood for the top of the table.
Any ideas or links on where I can find these?  I would preferably like the ones that attach on the corners and they should be 1" in size ( 3/4" MDF + 1/4" glass )
Thx - Corn
jelloslug
  • Last login:May 25, 2005, 03:55:59 pm
  • Splut!
    • Jelloslugs Arcade
Re:Where to find glass clips/retainers for cocktail cab ?
« Reply #1 on: July 18, 2002, 08:10:34 am »
All the clips that I have seen are for 1-1/4 thick tops (1" thick top + 1/4 thick glass).  Thats the standard thickness for a real cocktail.
Cornhoplio72
« Reply #2 on: July 19, 2002, 10:51:34 pm »
Anyone else have any leads on these clips ?
x-wing
  • Last login:March 28, 2003, 10:40:37 pm
  • I Built My Own Arcade Controls!!
« Reply #3 on: July 19, 2002, 11:32:13 pm »
Yeah, you can get cocktail glass clips from a couple of the usual parts suppliers:
http://www.twobits.com/parts/
http://www.mantisamusements.com/mrspacnos.htm
...but like jelloslug said, they will be for 1.25" thick, just how cocktail tops are supposed to be.  If you made yours a non-standard size, then you will probably have to make your own, as done on this project:  http://www.skum.org/gemini/finish.htm
