Author Topic: t-molding: happ vs. t-molding.com  (Read 1191 times)
SeanFu
  • Last login:May 22, 2004, 09:56:37 pm
  • I learn everything the hard way.
« on: April 03, 2004, 05:49:08 pm »
Just thought I would pass this along...
I just put the T-molding on my cab, all the way around both the side panels.  I used 3/4" smooth black.  I did one side with a roll from Happ and the other side with a roll from t-molding.com.  There is a difference between the two, and the t-molding.com stuff looks much smoother and has a more consistant surface.  The Happ stuff has a little bit if a ridge in the middle and for some reason I couldn't get it flattened down as consistantly.
I had assumed t-molding is t-molding, but there is some differences between suppliers.
Also - I had pretty good luck using a rolling pin to install it.  I just rolled along with a lot of pressure and it slipped right into the slot.
nipsmg
  • Last login:September 07, 2025, 07:37:55 pm
  • ROONEY!! ERRGH!!
    • Arcadia
Re:t-molding: happ vs. t-molding.com
« Reply #1 on: April 04, 2004, 12:40:37 am »
I have to agree.
So far t-molding.com has the best quality I've seen.. I had some small inconsistencies w/ Happ black t-molding before.
Just my $0.02
Gideon
  • Last login:August 24, 2024, 10:56:41 pm
« Reply #2 on: April 04, 2004, 09:56:43 pm »
Thanks for the tip!  I appreciate it.
bishmasterb
  • Last login:March 23, 2014, 09:27:47 pm
  • Pressing the limits of my wife's patience...
    • Bishopzone
« Reply #3 on: April 05, 2004, 12:30:57 pm »
I just ordered smooth orange t-molding from t-molding.com, and smooth black t-molding from Happs and have installed it on identical pieces of 3/4" MDF.
The t-molding.com stuff fits perfect and installed perfect (into 1/16" slot). The Happs stuff was difficult to install (didn't want to squeeze as easily into the 1/16" slot) and wasn't exactly 3/4", some of the edge of the wood shows (just a little, less than 1/16" for example, and is inconsistent at that).
I would have to say the t-molding.com stuff has worked out better for me too.
"We have just enough religion to make us hate, but not enough to make us love one another." -Jonathan Swift
rdagger
« Reply #4 on: April 05, 2004, 03:14:07 pm »
I was just going to order some 5/8" chrome T-Molding from Happ and now I am reluctant. :-\
I looked at T-molding.com but they only had the chrome in 3/4".
