Author Topic: Cap Kit problems, G07  (Read 1955 times)
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« on: March 30, 2004, 11:37:57 pm »
I just put a cap kit into a g07 (19") and I have a dark band on the top of the screen. Any suggestions?
Later,
dabone
(Monitor was working before, just doing the cap kit for maintenance.)
Ken Layton
  • Guru
  • Technician
Re:Cap Kit problems, G07
« Reply #1 on: March 31, 2004, 12:49:24 am »
Probably bad solder on one of the new caps you put it.
menace
« Reply #2 on: March 31, 2004, 06:39:21 am »
Check to make sure all your "-" and "+" are facing the right directions.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: March 31, 2004, 10:41:30 am »
Be sure to double check cap C302's polarity. Look in your capkit instructions as this cap's polarity markings on the pc board were wrong from the factory.
fredster
  • It's all good!
« Reply #4 on: March 31, 2004, 12:02:06 pm »
Check www.therealbobroberts.com  He's got a good trouble shooting guide in there dealing with cap kits.
dabone
  • Time to work...
« Reply #5 on: March 31, 2004, 11:52:38 pm »
Ok, I've removed all the caps, cleaned with a solder wick, removed all the resin and reinstalled. The problem I'm getting is the center of the screen is brighter than the top . (A solid red screen will be fine on the bottom half of the screen but the very top will be just grayer.
Using the nokia monitor test, the mouse pointer is white in the center but a dull nearly burnt orange color near the top.
I've manually degaussed the monitor with a real degaussing coil (no electric drills here).
Maybe one the non replacement caps?
Later,
dabone
Ken Layton
  • Guru
  • Technician
« Reply #6 on: April 01, 2004, 12:38:36 am »
Could be that 10 uf @ 160 volt cap on the neckboard?
dabone
  • Time to work...
« Reply #7 on: April 01, 2004, 01:19:53 am »
Nope did that one also, (put the original one back in just for a test also, no change)
Maybe the tube going?
Later,
dabone
p.s. This is a horrible burn in monitor that I've chosen to work on to refresh my skills before I recap my 2 25" k7000s.
Later,
dabone
