Author Topic: Localarcade.com Galaga CPO font?  (Read 3400 times)
glitch77
  • Last login:March 15, 2017, 09:25:48 pm
  • Pro Gear Spec!
    • My Hyper NeoGeo 64 Site.
« on: March 28, 2004, 11:37:40 am »
WHen I load up Illustrator, it says:
Code: [Select]
AvantGardelTCbyBT-book:
        Default font subtituted for missing font.
Where can I get the Galaga CPO font?
mahuti
Re:Localarcade.com Galaga CPO font?
« Reply #1 on: March 28, 2004, 12:18:39 pm »
I'm not sure, but I'll make sure that the font on the image online is converted to curves so that this isn't a problem.
mahuti
« Reply #2 on: March 28, 2004, 12:24:42 pm »
done. Try downloading again. If you get that message this time, just ignore it, I converted all the fonts to outlines.
glitch77
  • Pro Gear Spec!
« Reply #3 on: March 28, 2004, 12:52:37 pm »
What kind of community is this?!?
I've only posted a handfull of times, and I allready love this place!
Thanks alot!
mahuti
« Reply #4 on: March 28, 2004, 12:54:02 pm »
we do what we can.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #5 on: March 28, 2004, 04:04:38 pm »
That's weird. You are talking about the Galaga CPO that I did (for the upright cab)? I'm pretty sure I converted all fonts to outlines already. I drew that in CorelDRAW and since Illustrator was unable to work with the CorelDRAW text layout it had to be converted to outlines. As far as I know I didn't even use that font.
If objects actually used that font then I guess they now don't look as they should have.
My PC with Illustrator on it had a harddisk crash, but when I get it up and running again I'll check if any text was in that font (and in need of correction).
mahuti
« Reply #6 on: March 28, 2004, 04:10:12 pm »
I got a weird message when I opened the file about fonts, but it wasn't the typical message "you are missing xxx" It acted like the file had embedded fonts & said something about pdf... Whatever happened, the fonts converted & looked correct when I turned everything to outlines.
