Author Topic: perfect 360 joystick  (Read 1975 times)
tn01
« on: July 16, 2002, 02:34:01 am »
Hey y'all,
I'm considering switching the Happ Ultimate joystick in my homemade playstation controller with a perfect 360. However, I'm not sure how to go about powering the optical sensor (it requires a 5v source). Does anyone have any info on this/ know of any webpages?
Thanx
toilet
  • Last login:November 11, 2005, 11:53:45 am
    • Briefcase Emulator
Re:perfect 360 joystick
« Reply #1 on: July 16, 2002, 06:54:22 am »
Take a look at http://www.gamesx.com/controldata/psxcont/psxcont.htm. Pin number 5 VCC is the wire you want to connect the power to. You can just attach a wire to the PCB where that wire comes in, find it with a volt/multimeter. Hope this helps.
