Author Topic: A newbie question  (Read 1787 times)
diego313
  • Last login:March 24, 2004, 08:59:40 am
  • Hasta la vista!.
A newbie question
« on: March 23, 2004, 03:33:01 pm »
Hi all,
   Could someone explain me how to map the keyboard (hacked) to the controls.
   I mean , I'm planning to have 2 joysticks and six button per joystick so basically I want the mapping that I've to do , something like
   Joystick 1 -UP Movement -> Up Arrow
   Joystick 1 -Diagonal up-right movement -> ???
   and so on.
Thansk all!
Zathras
  • Last login:June 06, 2011, 01:06:02 am
  • Yeah.
Re:A newbie question
« Reply #1 on: March 23, 2004, 03:39:14 pm »
Diagonals are a combination of keypresses so pressing up and right = up right diagonal.
Space Warped by Someone
diego313
  • Hasta la vista!.
« Reply #2 on: March 23, 2004, 03:47:17 pm »
that means that I've to wire both key to the same contact in the joystick?
Mugzilla
  • Last login:May 23, 2020, 03:25:47 pm
  • Negative Ghost Rider,...
« Reply #3 on: March 23, 2004, 04:06:04 pm »
No, when you push up on a j-stick, it closes the UP contact.
When you push right on a j-stick, it closes the RIGHT contact.
when you push UP AND RIGHT on a j-stick, it closes the UP and RIGHT contact.
Stingray
« Reply #4 on: March 23, 2004, 04:21:23 pm »
Or to put it another way, an eight-way stick only has four switches. Diagonals are when two switches are pressed at once.
-S
« Last Edit: March 23, 2004, 04:21:50 pm by Stingray »
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: March 23, 2004, 04:33:09 pm »
Hi all,
Apollo
    • Eight Bells
« Reply #6 on: March 23, 2004, 10:04:04 pm »
PEOPLE ARE STILL HACKING KEYBOARDS! WHY?
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: March 24, 2004, 06:41:00 am »
Good point, I should have mentioned that for the time and aggravation, it will be less expensive and more satisfying to buy a KeyWiz ECO www.groovygamegear.com and have a dedicated arcade game control designed encoder in you cab/controller.
diego313
  • Hasta la vista!.
« Reply #8 on: March 24, 2004, 09:00:28 am »
thanks to all
Stingray
« Reply #9 on: March 24, 2004, 09:42:17 am »
I guess I should have chimed in with that as well. My hacked keyboard gave me plenty of headaches. I recently replaced it with an IPAC. That was the best money I've spent on my cab.
-S
