Author Topic: ArcadeFX Setup  (Read 1243 times)
CampRicco
  • Newbie
  • Last login:March 22, 2004, 12:32:06 pm
ArcadeFX Setup
« on: March 22, 2004, 12:41:20 pm »
I have been trying to configure this software and I am a bit confused. The documentation says that it runs with mame32 but every time I go to load a game, the software prompts me to locate my mame.exe. (Not mame32.exe). Any thoughts.
Mike
  • Last login:September 22, 2005, 01:22:14 pm
  • Umm, yea about the TPS report
Re:ArcadeFX Setup
« Reply #1 on: March 22, 2004, 01:49:38 pm »
Rename the executable to mame.exe instead of mame32.exe. It will fix the problem.
Lilwolf
Re:ArcadeFX Setup
« Reply #2 on: March 23, 2004, 07:58:19 pm »
I wouldn't spend to much time on it.
It hasn't been updated in ages.  And it uses a database that I dont' believe there is an easy / automatic way to update...
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
Re:ArcadeFX Setup
« Reply #3 on: March 23, 2004, 10:22:36 pm »
Yeah, it seems like the author bailed on it.
It did look very promising, as well as his/her jukebox proggy.
%$#@!&* machine took my quarter!
Mike
Re:ArcadeFX Setup
« Reply #4 on: March 24, 2004, 08:38:54 am »
Yeah ed just disappeared. I still currently use ArcadeFX, I've used it now for probably 2 years. It does everything I need it to do. I pretty much only use mame as those are the games most people want to play anyways. If I get on a kick to play space ace or something I will usually just fire that off manually. I have the database up to I believe .74. It's not that big of a hassle to update if you know access. I'll probably keep using it until the next version of DK comes out with all the bells and whistles, then all get off my lazy keister and do something different with my arcade.
