Author Topic: Keyboard LED lights, all 3?  (Read 1811 times)
spauldingd
  • Last login:February 18, 2022, 11:41:51 am
« on: March 20, 2004, 11:08:58 am »
I got my IPAC and Optipac from Ultimarc yesterday and for that extra adde bling factor I also got their 3-LED light harness for the keyboard LED indicators.
Can anyone tell me of a game that uses all 3 LED's?  Ms. Pacman is a good example of one that lights up 2 lights, but I have yet to find a game that lights up the Scroll Lock LED.
Mainly, I want to know if I really need to drill a hole in my future panel for an LED that will seldom if ever be lit.
Dave
SirPeale
  • Green Mountain Man
Re:Keyboard LED lights, all 3?
« Reply #1 on: March 20, 2004, 11:42:16 am »
I believe only the first two get used for credits, but the third lights up for games like "Spy Hunter" for the 'van' light and 'Out Run' for the brake, but I could be wrong about that.  Off for testing!
SirPeale
« Reply #2 on: March 20, 2004, 11:47:54 am »
Well, Out Run uses the caps lock light, and I couldn't get Spy Hunter to do anything.
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: March 20, 2004, 02:03:09 pm »
Dave
I know Ajax uses all three, but I could never figure out what the Scroll Lock one meant.  I was planning to leave it off, but if it turns out I need it for the Van Light in SpyHunter, I'll be bummed.
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: March 22, 2004, 08:34:39 am »
Dave
Did some more digging -
SpyHunter definitely does not use the LED's however, newer builds flash the Van light onscreen under the bezel artwork.
Ajax flashes the scroll lock LED when you collect a power-up, but the power-up also flashes in the game on-screen, so it's not really important.
If you do a search in the MAME source code for files containing "set_led_status", you will come up with about 70 drivers which flash the LED's, but I couldn't go any further than this.
spauldingd
« Reply #5 on: March 22, 2004, 08:55:35 am »
I spent some hours doing my own "research" and found that none of the games I play on a regular basis use the scroll-lock LED on the keyboard, so I believe I will non-destructively remove it from my IPAC LED harness so I can put it back at some point.
To power my coin-door lights, I am using the +12V wire from a power connector off my PC power supply.  What I think I will do is connect the +5V wire to this spare LED and mount it right next to my power button on the panel.
Dave
