Author Topic: Save monitor glass or dump?  (Read 1490 times)
jimmyjet
  • Last login:June 03, 2008, 06:39:55 am
« on: March 19, 2004, 03:32:19 pm »
I took a non-functioning 25" monitor out of a used up cabinet recently.  The monitor was missing all the circuit boards and wiring that should be present with a functioning unit.  Basically all I have is the glass.  Does this have any value or should I take it to the dump before someone drops it?
jimmyjet
SirPeale
  • Green Mountain Man
Re:Save monitor glass or dump?
« Reply #1 on: March 19, 2004, 05:54:10 pm »
I would say dump.  Without the boards there's not much use for it, since you can get another tube from a TV shop for cheap, if not free.
Ken Layton, your opinion?
Ken Layton
  • Guru
  • Technician
« Reply #2 on: March 19, 2004, 06:10:37 pm »
If the yoke, degaussing coil, and ground strap are still on it then the tube may still be good! Get either a brand new 8liners chassis for it or if you know what make/model the monitor is look on ebay for a used chassis to restore it to operational status.
If the yoke, degaussing coil, and ground strap are gone the chances are the tube is garbage and you should throw it away.
jimmyjet
« Reply #3 on: March 19, 2004, 09:08:23 pm »
Thanks for the responses.  There is nothing there but a piece of glass.  Beautifully molded glass, but alas just glass.  Time for the dumpster.
jimmyjet
paigeoliver
  • Awesome face!
« Reply #4 on: March 19, 2004, 10:10:07 pm »
I don't keep mystery tubes either. If it is just a tube, and I don't know the status of it, and don't have a compatible chassis to test it, then I chuck it out. I DO keep working tubes around though.
