Author Topic: how to set resolution in mame?  (Read 1798 times)
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« on: March 17, 2004, 02:21:48 pm »
i use mamewah with a athlon optimized version of mame. when i used to use mame32 there was an option to make all games display in 1024 resolution. how can i do this with mamewah/mame ?
also is there a way to disable scandisk when you start your computer, if you dont shut down properly it does that scan.. i want to disable that
"Owens is the ringleader in the ass hat circus"  D K
Magnet_Eye
  • Last login:May 11, 2020, 09:26:19 pm
  • Feel the heat?
    • Web Hosting deals for BYOAC Users!
Re:how to set resolution in mame?
« Reply #1 on: March 17, 2004, 05:36:00 pm »
in your mame.ini file, change resolution to 1024x768 or any desired resolution you wish.
 8)
« Last Edit: March 18, 2004, 08:18:17 pm by Magnet_Eye »
I offer discounted WEB HOSTING to BYOAC members! Only $2.49 a month for a FULL FEATURED account! www.cloud9media.com
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: March 18, 2004, 10:09:06 am »
I don't think you can do it directly from windows.  It might be an option in TweakUI, or I'm pretty sure there are freeware apps to disable it, but I don't know of a specific one.
Mr. Dude
  • Last login:March 03, 2019, 05:12:50 am
  • Hi...
« Reply #3 on: March 18, 2004, 02:23:02 pm »
If you click on "Start" then "RUN" and type in "msconfig."  You can select Advanced under the General tab section and then check the "disable scandisk after bad shutdown option."  I'm not sure if this works in all versions of windows though but you can give it a shot.
« Last Edit: March 18, 2004, 04:43:17 pm by Mr. Dude »
Sephroth57
  • Poo Monkey
    • Check it out!!!
« Reply #4 on: March 19, 2004, 08:58:36 am »
thanks ill try that for the scandisk
also i couldnt seem to find my mame.ini file, should it be in the same folder as my mame.exe?
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: March 19, 2004, 09:12:46 am »
It works in Win'98, changed mine last night.  Thanks, Mr. Dude.
>also i couldnt seem to find my mame.ini file, should it be in the same >folder as my mame.exe?
Yes, but I don't think it comes as part of MAME.
Get to a dos (Command) prompt (Accessories tab), cd (Change directory) to your mame folder and type "Mame -cc" (no quotes) and enter, and MAME will build one that you can modify.
Mr. Dude
  • Hi...
« Reply #6 on: March 19, 2004, 11:50:31 am »
No problem... Glad I could help. :)
Sephroth57
  • Poo Monkey
    • Check it out!!!
« Reply #7 on: March 19, 2004, 01:12:52 pm »
cool ill try that when i get home, thanks
