Author Topic: MDF sawblade?  (Read 996 times)
crashwg
MDF sawblade?
« on: March 11, 2004, 12:20:49 pm »
Is there a specific type of circular saw blade I should use to cut MDF?  I wan't the edges to be as smooth as posible after the cut, so I was thinking maybe a plywood blade, but I don't realy know what I should get.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Wade
  • Last login:December 01, 2025, 08:21:17 am
  • 80's Child
    • Wade's Gameroom
Re:MDF sawblade?
« Reply #1 on: March 11, 2004, 01:00:14 pm »
I bought a blade that was special for MDF and it sucked.  It was slow and dulled after a few cuts.
I ended up using a rough cut carbide tipped blade (I think around 22 teeth).  After a little practice, I was making straight cuts quickly and with a very smooth edge.
Wade
brooksware2000
  • Last login:April 20, 2004, 12:38:50 am
    • Hobbybotics.com
Re:MDF sawblade?
« Reply #2 on: March 13, 2004, 12:19:12 pm »
Get yourself a 60 tooth carbide blade used for smooth and finish cuts. Works great and does not hang or burn the wood like steel blades do. MAKE sure the blade is carbide.
