Author Topic: LEDBlinke Startet nicht unter windows 11  (Read 3183 times)
kkgrafics
  • Last login:January 12, 2026, 01:32:14 am
« on: January 07, 2026, 02:18:27 pm »
Hallo
ich bin der Mario und habe folgendes Problem.
Hi everyone,
I’m having an issue with LEDBlinky using my PacLED64 and two Arduino MICROs as controllers for Player 1 and 2.
Setup:
Arcade cabinet with 2 players, each with 6 buttons + joystick
Additional buttons: Start, Select, Pause, 1-Player, 2-Player, and Flipper buttons
Each button has an LED
InputMap for all buttons created and working (keycodes are recognized)
Problem:
The LEDBlinky GUI does not appear when started
LEDs do not respond automatically to button presses
Using SimpleLEDTest, I can manually test all ports → hardware works fine
What I’ve tried:
Reinstalled the latest LEDBlinky version
Copied InputMap files
Tested all ports via SimpleLEDTest → all LEDs work
Tried various CMD commands → no effect
Questions:
Are there known reasons why the GUI does not appear?
Is there a workaround to control LEDs automatically without the GUI?
Thanks in advance for any help!
kkgrafics
Re: LEDBlinke Startet nicht unter windows 11
« Reply #1 on: January 08, 2026, 01:55:15 am »
Which version of Windows does LEDBlinky run on? Does it even work under Windows 11? Does anyone else have this problem?
Unter welcher Windowsversion Läuft denn das LEDBlinky? Funktioniert das überhaupt unter windows 11? Wer Kennt dieses Problem?
