Author Topic: Trackball Mounting Plate?  (Read 1078 times)
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
« on: March 10, 2004, 01:58:24 pm »
I have an Imperial 3" Golden Tee Golf TrackBall Assembly without a mounting place.
Can I use a 3" from happs on this item?
PS. Anyone else have this type of trackball?
Stingray
Re:Trackball Mounting Plate?
« Reply #1 on: March 10, 2004, 02:02:25 pm »
I have the same trackball. I'm mounting mine on a custom made metal CP so I won't be using any type of mounting plate at all on mine.
-S
GGKoul
  • Cheesecake Apprentice
« Reply #2 on: March 10, 2004, 02:20:29 pm »
Yes you can.
DougHillman
  • Last login:September 13, 2004, 07:39:18 pm
« Reply #3 on: March 10, 2004, 04:19:39 pm »
-S
So then, what was your point of posting this response?
Just wondering why people do this.
D
If you can't be a good example at least try to be a horrible reminder.
Stingray
« Reply #4 on: March 10, 2004, 04:25:42 pm »
He asked if anyone else has this trackball. I do, but posted that I'm mounting mine differently than he is so he wouldn't think I neglected to answer the part about the mounting plate. I thought he possibly had another question in mind specific to this type of trackball, but unrelated to the mounting plate.
-S
DougHillman
« Reply #5 on: March 10, 2004, 04:34:49 pm »
Heh.  My bad.  I scanned through his question too quickly and dind't notice his PS.
chrisindfw
  • I drank what?
« Reply #6 on: March 10, 2004, 04:40:58 pm »
I do have another question. I got this off of ebay and am awaiting for it to arrive. Does anyone have a mouse hack I can see to connect this to my pc? Also, is this a high ball?
-S
SirPeale
  • Green Mountain Man
« Reply #7 on: March 11, 2004, 09:12:06 am »
Sure.  However, I've since learned that the 'ground' that is in that pictures is not the ground at all.  I've got to trace the actual ground.
Stingray
« Reply #8 on: March 11, 2004, 09:46:46 am »
Mine is being connected to an older Mac that uses ADB mice. On the off chance that you're doing the same thing I'll be happy to take close ups of my mouse hack. In any case, it's very easy to do. Read through Minwah's mouse hack tutorial, that told me everything I needed to know:
http://mamewah.mameworld.net/mousehack.html
With this particular trackball you've got two red wires (5v+), two black wires (5v-), two green wires (ground). The other four wires are for the optical directions. I just hooked them up by trial and error until I figured out which was which. Only took a couple of tries.
-S
SirPeale
« Reply #9 on: March 15, 2004, 05:03:42 pm »
I just wanted to update that I found the ground on this mouse, it was the green wire.
