Author Topic: Need Advice: Reinforcing Particle Board Control Panel for Joystick  (Read 23186 times)
Al_Comandante
  • Last login:December 31, 2025, 01:51:43 am
After going back and forth for a long time, I finally got myself a cabinet kit. So far, everything is fine. Unfortunately, I have one major problem. Probably due to carelessness, I ordered the kit in particle board instead of MDF. That’s a bit annoying, but not a huge issue overall.
BUT: I don’t really trust the particle board when it comes to the joystick. I’m very worried that sooner or later something will tear out. That’s why I’d like the panel to be reinforced with wood from underneath, and I also want the screws to go all the way through the panel — meaning that the screws will be visible from the top. I’ve read that this method is absolutely rock-solid and tear-proof.
Unfortunately, I lack the imagination to picture what this looks like or how exactly I should screw, glue, or attach something under the panel. I haven’t been able to find any pictures either.
I hope someone here can show me pictures of what it’s supposed to look like.
Maybe also important: On top of the 16 mm particle board there is an additional 3 mm acrylic sheet. Is that critical in any way?
