Author Topic: IPac 2 and Happ Perfect 360  (Read 1161 times)
enb141
  • Last login:March 10, 2004, 09:39:11 am
« on: March 10, 2004, 09:43:25 am »
Hi, I'm new here and I would like to know if there's a way to connect IPac 2 with Happ Perfect 360, I don't know if it's possible because IPac doesn't have a pin with 5V+, does anyone knows if it's possible to connect Happ Perfect 360 + IPac 2 I will appreciate it.
Tiger-Heli
    • Tiger-Heli
Re:IPac 2 and Happ Perfect 360
« Reply #1 on: March 10, 2004, 12:14:25 pm »
The I-PAC has +5V on the LED pin header.  See the diagram at the bottom of this page:  http://www.ultimarc.com/ipac2.html
An easy way to tap into it is to use a CD-Rom drive audio cable and run that wire to a terminal block.
enb141
« Reply #2 on: March 10, 2004, 12:49:08 pm »
