Author Topic: Merit Megatouch XL6000 hard drive issue  (Read 11069 times)
apinbalwiz
  • Last login:August 12, 2025, 04:03:57 pm
« on: July 28, 2025, 03:12:07 pm »
Hi
I'm a real newbie with this...I picked up a Merit Megatouch XL6000 machine that only displays solitaire games. I was told that the hard drive causes this, I had my son clone it but the results are the same. Is there something else that needs to be done to get it going?  Thanks!!
Megatouchmike
  • Last login:September 19, 2025, 01:43:48 pm
Re: Merit Megatouch XL6000 hard drive issue
« Reply #1 on: July 30, 2025, 07:21:55 am »
XL 6000 is CD based so assuming it's been updated to a newer version. Anyway it's likely the nvram has been corrupted so try a two button clear
apinbalwiz
« Reply #2 on: August 01, 2025, 05:31:12 pm »
Thank you for your reply!  I tried the 2 button clear (I think the 2 buttons are the ones labeled set-up and calibration) but I get 2 Invalid drive specification errors and a Bad command or filename D:\> error. This is with a new hard drive - if I put the old one back in I get to the solitaire stuff.  Please help!!! :dizzy:
« Last Edit: August 01, 2025, 07:57:59 pm by apinbalwiz »
Megatouchmike
« Reply #3 on: August 02, 2025, 08:34:25 am »
Do the clear with the old drive
apinbalwiz
« Reply #4 on: August 02, 2025, 12:20:28 pm »
Thank you again, I will. Just to be sure do I do this with the power off or on?
apinbalwiz
« Reply #5 on: August 03, 2025, 07:45:57 pm »
When I thought about it I realized that was a stupid question. I did it with the power on, and it WORKED! Was told by many it was a hard drive issue.
Thank you SO much, I didn't know those buttons were in there!  You are the MAN!!  :applaud:
