Author Topic: IPAC Four repeating input  (Read 221 times)
Charlzyefc
  • Last login:June 26, 2025, 12:48:40 pm
« on: June 26, 2025, 06:20:34 am »
I’ve bought a 4 player arcade cabinet with 4 coin mechanisms the machine is second hand and it’s a bit of a project, the cabinet has come with an IPAC Four all wired up and I’m having no issues with any of the buttons, joysticks etc but I’m having an issue with one of the four coin mechanisms, when I power the cabinet and the IPAC I get a constant repeating key stroke, the number 5, that doesn’t stop until I interrupt it by pressing another button, at first I thought the coin mech was faulty so I’ve replaced it, then I thought the wiring was faulty so I’ve replaced it and fully tested it, I believe it’s an issue with the ‘1COIN’ input where the player 1 mechanism is wired, even when I fully disconnect the wiring and power to ‘1COIN’ it still repeats, I have reflashed the board and had no luck I’ve tried mapping to a different key, the only thing I haven’t done is change to a different spare input on the board, seems a shame to do that because all the cables are nice and neat the way they are and I’d risk damaging cables snipping cable ties off.
Could you think of any other fix for this or shed some light on why it may be happening?
Could it just be a faulty input/switch?
Any help appreciated.
Thank you.
Dan.
MartyKong
  • Last login:Yesterday at 10:36:48 am
Re: IPAC Four repeating input
« Reply #1 on: Yesterday at 10:08:40 am »
First off I'm probably not the best one to try to answer this question but......  I'd start by disconnecting the coin mech, attach the wires to a spare arcade button, open notepad and one press should equal one 5. Then open the winIpac software just in case there's a repeat selection (don't know if that that's an option). Other than that make sure there's no other software installed causing this behavior. Wish I could be more help😐
_Iz-
  • Last login:Yesterday at 09:28:05 pm
  • Time to coin up!
« Reply #2 on: Yesterday at 02:35:21 pm »
You could also try disconnecting the wires completely from that one input. If it still does it, then the problem is most likely related to the ipac itself
