Author Topic: Question about performance on GroovyMAME...  (Read 8577 times)
purbeast
  • Last login:January 03, 2026, 01:02:11 pm
« on: June 07, 2025, 01:57:38 pm »
I experienced some strange behavior recently.
I have groovyMAME setup on my 320x240 CRT with crt-emudriver and I noticed when I started up Area 51 that it was laggy and very choppy, but I thought nothing of it as I changed versions of MAME and was using old ROMs, and I'm probably going back to my older version anyways.
However when I was doing some setup on it I had it hooked up to my HD monitor via HDMI and when I ran Area 51 just to test something out, I noticed it was running fine.
Then I tried again on my CRT and yep, it was choppy and laggy.
So my question is - is there some setting that is making it run choppy when it loads up in the CRT resolution?
haynor666
  • Last login:January 09, 2026, 02:33:07 pm
  • retro maniac
Re: Question about performance on GroovyMAME...
« Reply #1 on: June 16, 2025, 04:00:23 pm »
Atari jaguar driver is right now very CPU demanding. Area 51 runs right about 125% on my i5-10600KF.
I observed that to fully synchronize on CRT groovymame needs a slight more power than regular mame. In this case this might be a noticable difference.
peterson65
  • Last login:December 13, 2025, 03:57:23 pm
« Reply #2 on: June 16, 2025, 04:10:36 pm »
something did change since 0.247. i posted to mametesters and they confirmed it. runs perfect with 0.246. maximum force also
haynor666
  • retro maniac
« Reply #3 on: June 16, 2025, 04:27:34 pm »
Version 252 seems to be fine.
purbeast
« Reply #4 on: June 19, 2025, 08:28:51 pm »
Oh wow okay that would explain my situation then, I was not aware of that.
