Author Topic: JVL Echo iTouch HD3 Software image  (Read 12065 times)
MorganTA
  • Last login:May 31, 2025, 07:15:37 pm
« on: May 09, 2025, 04:34:51 pm »
I need to reset the access pin on a JVL Echo HD3. I tried removing the battery and resetting the bios, and a factory reset but nothing has worked so far.
At this point I'm guessing reinstalling the software is my best bet, but I haven't been able to find any images of the software online.
Would anyone be able to share it with me?
Megatouchmike
  • Last login:September 19, 2025, 01:43:48 pm
Re: JVL Echo iTouch HD3 Software image
« Reply #1 on: May 12, 2025, 07:13:09 am »
The pin is set on the ioboard and therefore will persist through a software reinstall
MorganTA
« Reply #2 on: May 13, 2025, 12:09:02 pm »
Oh shoot that's a pain. Any ideas on how I can reset/bypass it? Maybe I did something wrong with my first attempts.
Megatouchmike
« Reply #3 on: May 14, 2025, 05:06:06 pm »
You used to be able to call Jvl and they could generate a reset code. Not sure if you can still get a hold of anyone there. Otherwise you could dump the io eeprom. I think I checked before and the pin was in clear text
MorganTA
« Reply #4 on: May 15, 2025, 04:30:31 pm »
Thanks! I'll give that a try.
Is there any instructions anywhere on how to dump the io eeprom? It looks like the programmer I have isn't compatible with this chip.
Megatouchmike
« Reply #5 on: May 16, 2025, 07:28:06 am »
I doubt any guide exists for this. I believe I dumped mine with flashROM and ch341a such as this
https://ebay.us/m/uQ80xE
Please post back so others know how you make out
