Author Topic: Can I get any rumble on wii remote when paired with dolphin mayflash mode 4?  (Read 2138 times)
jcvd12
  • Last login:April 05, 2025, 04:40:26 pm
All I wanted was for wii remote to rumble everytime I pressed the B button or trigger, for lightgun games,  on any game (windows or maybe teknoparrot and games that work with touchmote on mode 4.
Can somebody please help me? I
Im willing to pay a good coffee or beer for step by step solution
« Last Edit: March 31, 2025, 09:16:26 am by jcvd12 »
jcvd12
I tried using Glovepie it worked once, could play the games with rumbling when pressing the trigger, but worked only one time. Now it rumbles non stop until i have to long press shut down on the wii remote. I thought i had something really nice but it vanished. There must be some way of getting the trigger and reload to rumble. But im clueless.. Please anyone
jcvd12
If you master touchmote on mode 4 youll never have to mess with demulshooter or ahk in your life ever again.
I just need the tweaks to make it rumble or have ffb. Im positive i will get help from a friend. This one guy wont ignore me like ive been ignored so far
Tiberius
  • Last login:April 02, 2025, 03:12:41 pm
  • Spent more time fixing than playing
It is possible to get a Wiimote to vibrate whilst pretending to be a Xbox controller via Touchmote using AHK.
https://www.autohotkey.com/board/topic/35848-xinput-xbox-360-controller-api/
The above is a link explaining how to do it and use it.
Or copy and paste the code below for ahk without having to read up on it
Code: [Select]
#NoEnv  ; Recommended for performance and compatibility with future AutoHotkey releases.
; #Warn  ; Enable warnings to assist with detecting common errors.
SendMode Input  ; Recommended for new scripts due to its superior speed and reliability.
SetWorkingDir %A_ScriptDir%  ; Ensures a consistent starting directory.
#SingleInstance Force
XInput_Init()
XInput_Init()
Loop {
Loop, 4 {
if State := XInput_GetState(A_Index-1)
        BT := State.wButtons
if BT = 0x1000
XInput_SetState(A_Index-1, 0, 65535)
Sleep, 100
XInput_SetState(A_Index-1, 0, 0)
return
XInput_Init(dll="xinput1_3")
    global
    if _XInput_hm
        return
    ;======== CONSTANTS DEFINED IN XINPUT.H ========
    ; NOTE: These are based on my outdated copy of the DirectX SDK.
    ;       Newer versions of XInput may require additional constants.
    ; Device types available in XINPUT_CAPABILITIES
    XINPUT_DEVTYPE_GAMEPAD          := 0x01
    ; Device subtypes available in XINPUT_CAPABILITIES
    XINPUT_DEVSUBTYPE_GAMEPAD       := 0x01
    ; Flags for XINPUT_CAPABILITIES
    XINPUT_CAPS_VOICE_SUPPORTED     := 0x0004
    ; Constants for gamepad buttons
    XINPUT_GAMEPAD_DPAD_UP          := 0x0001
    XINPUT_GAMEPAD_DPAD_DOWN        := 0x0002
    XINPUT_GAMEPAD_DPAD_LEFT        := 0x0004
    XINPUT_GAMEPAD_DPAD_RIGHT       := 0x0008
    XINPUT_GAMEPAD_START            := 0x0010
    XINPUT_GAMEPAD_BACK             := 0x0020
    XINPUT_GAMEPAD_LEFT_THUMB       := 0x0040
    XINPUT_GAMEPAD_RIGHT_THUMB      := 0x0080
    XINPUT_GAMEPAD_LEFT_SHOULDER    := 0x0100
    XINPUT_GAMEPAD_RIGHT_SHOULDER   := 0x0200
    XINPUT_GAMEPAD_A                := 0x1000
    XINPUT_GAMEPAD_B                := 0x2000
    XINPUT_GAMEPAD_X                := 0x4000
    XINPUT_GAMEPAD_Y                := 0x8000
    ; Gamepad thresholds
    XINPUT_GAMEPAD_LEFT_THUMB_DEADZONE  := 7849
    XINPUT_GAMEPAD_RIGHT_THUMB_DEADZONE := 8689
    XINPUT_GAMEPAD_TRIGGER_THRESHOLD    := 30
    ; Flags to pass to XInputGetCapabilities
    XINPUT_FLAG_GAMEPAD             := 0x00000001
    ;=============== END CONSTANTS =================
    _XInput_hm := DllCall("LoadLibrary" ,"str",dll)
    if !_XInput_hm
        MsgBox, Failed to initialize XInput: %dll%.dll not found.
        return
    _XInput_GetState        := DllCall("GetProcAddress" ,"ptr",_XInput_hm ,"astr","XInputGetState")
    _XInput_SetState        := DllCall("GetProcAddress" ,"ptr",_XInput_hm ,"astr","XInputSetState")
    _XInput_GetCapabilities := DllCall("GetProcAddress" ,"ptr",_XInput_hm ,"astr","XInputGetCapabilities")
    if !(_XInput_GetState && _XInput_SetState && _XInput_GetCapabilities)
        XInput_Term()
        MsgBox, Failed to initialize XInput: function not found.
        return
XInput_GetState(UserIndex)
    global _XInput_GetState
    VarSetCapacity(xiState,16)
    if ErrorLevel := DllCall(_XInput_GetState ,"uint",UserIndex ,"uint",&xiState)
        return 0
    return {
    (Join,
        dwPacketNumber: NumGet(xiState,  0, "UInt")
        wButtons:       NumGet(xiState,  4, "UShort")
        bLeftTrigger:   NumGet(xiState,  6, "UChar")
        bRightTrigger:  NumGet(xiState,  7, "UChar")
        sThumbLX:       NumGet(xiState,  8, "Short")
        sThumbLY:       NumGet(xiState, 10, "Short")
        sThumbRX:       NumGet(xiState, 12, "Short")
        sThumbRY:       NumGet(xiState, 14, "Short")
XInput_SetState(UserIndex, LeftMotorSpeed, RightMotorSpeed)
    global _XInput_SetState
    return DllCall(_XInput_SetState ,"uint",UserIndex ,"uint*",LeftMotorSpeed|RightMotorSpeed<<16)
XInput_GetCapabilities(UserIndex, Flags)
    global _XInput_GetCapabilities
    VarSetCapacity(xiCaps,20)
    if ErrorLevel := DllCall(_XInput_GetCapabilities ,"uint",UserIndex ,"uint",Flags ,"ptr",&xiCaps)
        return 0
    return,
    (Join
            Type:                   NumGet(xiCaps,  0, "UChar"),
            SubType:                NumGet(xiCaps,  1, "UChar"),
            Flags:                  NumGet(xiCaps,  2, "UShort"),
            Gamepad:
                wButtons:           NumGet(xiCaps,  4, "UShort"),
                bLeftTrigger:       NumGet(xiCaps,  6, "UChar"),
                bRightTrigger:      NumGet(xiCaps,  7, "UChar"),
                sThumbLX:           NumGet(xiCaps,  8, "Short"),
                sThumbLY:           NumGet(xiCaps, 10, "Short"),
                sThumbRX:           NumGet(xiCaps, 12, "Short"),
                sThumbRY:           NumGet(xiCaps, 14, "Short")
            Vibration:
                wLeftMotorSpeed:    NumGet(xiCaps, 16, "UShort"),
                wRightMotorSpeed:   NumGet(xiCaps, 18, "UShort")
XInput_Term() {
    global
    if _XInput_hm
        DllCall("FreeLibrary","uint",_XInput_hm), _XInput_hm :=_XInput_GetState :=_XInput_SetState :=_XInput_GetCapabilities :=0
Using Wiimotes, Demulshooter and Touchmote as lightguns......does actually work!!!
