Author Topic: A single beep from the motherboard.. and then slowdown  (Read 11953 times)
Truz
  • Last login:February 23, 2009, 12:03:01 pm
« on: March 08, 2004, 02:37:16 pm »
Well i have been having a problem lately with mame. I am using the latest version of mame with mamewah if anyone needs to know, so here is my problem.
When playing certain game (like MvC, SFA3) I will hear a beep from the motherboard and the game will slowdown but then kick back to normal within about 5-10 secs. It is the same kind of beep you hear when pressing one too many keys at the same time within windows. I think this happens when i mash buttons in MvC (on certain moves you get more hits if u mash) so is there any fix to this. I am pretty sure this is the problem because it is just a single beep and thats what happens in windows when you press one too many keys.
Is there a solution to this or should i just stop mashin the damn buttons, haha. Also i am using an x-arcade solo stick. thanks for any input guys.
PaulG
  • Last login:April 10, 2007, 03:25:56 pm
Re:A single beep from the motherboard.. and then slowdown
« Reply #1 on: March 08, 2004, 07:09:53 pm »
Well if you figure out what BIOS your motherboard is using, the codes are easy to find on google (Ex. Phoenix Bios codes).  Noticed on one particuliar BIOS one beep meant bad RAM.
Not sure if that's relevant.  Never actually heard a beep from pressing too many keys.   But it's a start if you wanna figure out BIOS beeps.
Truz
« Reply #2 on: March 09, 2004, 09:09:09 am »
well i looked into it and i found out that a single beep mean this:
ERROR message: Refresh Failure
Description: The memory refresh circuitry on the baseboard is faulty.
Now what does that mean and how would i go about solving this problem. Now i have only really experienced this problem in mame (dont do much else oon that pc) and really only in the more recent system taxing games. And the slowdown is bearable as it only lasts a couple seconds and then it kicks back in normally. So can anyone point me in the right direction to solving this problem? thanks
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: March 09, 2004, 09:30:38 am »
If it's happening during the game itself, the BIOS codes are irrelevant, so ignore that line of logic.
One of the encoder designers could answer this better (RandyT ?), but.
It's possible the motherboard is not polling the PS/2 or USB? port fast enough.  Or it's possible you have some kind of ghosting with the X-Arcade encoder.
Try this - download Ghostkey or one of the other keyboard utilities from the utils section of the main page.  Fire it up.  Press EVERY X-Arcade button and move the joysticks to all the diagonals.
If you hear any beeps, you found your problem (although you still won't be sure if it's X-arcade or motherboard port ;-(( )
Lilwolf
« Reply #4 on: March 09, 2004, 09:40:31 am »
one more note...
didn't x-arcades have a patch?  Might have been for that.
and ghostkey is a good bet... tests that it happens outside of mame... plus you will get a visual on whats happening.
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: March 09, 2004, 09:47:44 am »
one more note...
I didn't see a patch, but they do have a test program at http://www.xgaming.com/service.shtml as another diagnostic check.
And they have a toll-free 1-866 support number if all else fails.
Truz
« Reply #6 on: March 09, 2004, 09:49:16 am »
ok i will try that guys, thanks for your input.
Oh and i just realized something. I have the x-arcade going straight into the ps2 port without ps2 keyboard going through the x-arcades pass through port. Instead i have a usb keyboard plugged in separately of the x-arcade. Could this be causing a conflict? I dont remember any documentation about this, but I just started using the x-arcade on this pc and i only have a usb keyboard for it. Do you think this could be causing a problem?
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: March 09, 2004, 09:55:25 am »
Highly doubtful.
X-arcade says something in their FAQ's about the PS/2 port sometimes not supplying enough power for the X-arcade, which seems unlikely as well, but more likely than your USB keyboard.
If possible, though, either try using the USB adapter (if you have one) to run the X-arcade to USB, or start MAMEWAH, unplug the USB keyboard, and see if the problem goes away.
If it is the problem, you can probably find a PS/2 keyboard to use with it either free with rebate or under $5-$10 somewhere.
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #8 on: March 09, 2004, 10:00:21 am »
  Welp, if the problem is your motherboard then most likely the solution is a new motherboard (unfortunately).  Generally there's no fixing those kinds of things. However, you can try and troubleshoot it enough to get a good idea what exactly the problem is.
  baseboard = motherboard.  If, in fact, this error message is correct, try messing around with the memory settings in your BIOS (latency, etc) or swapping out your memory for new sticks, if you have any available. If you have to buy them then it's probably cheaper to get a new motherboard.
  What are the specs of your computer?
   It might make sense that when you're playing one of these games that MAME exercises the memory more than usual, and it's probably safe to assume that when you're 'mashing buttons' that a lot is going on at once on the screen, no?
  If the other things that people posted don't enlighten you as to what your problem is, I'd try and download a memory tester or benchmark program from Tucows and see if by running one of those utilities that it causes your motherboard to beep.
  Honestly, though, I would bet the problem is not with your motherboard or memory but with Windows not allowing your X-Arcade to send all those keys at once.
  What's the point of having an arcade if you can't get a little rough once in a while? :)
/Steve
Tiger-Heli
    • Tiger-Heli
« Reply #9 on: March 09, 2004, 10:09:39 am »
/Steve
Again, ignore ALL these posts about BIOS codes and Error Messages and Baseboards.
Motherboards beep a single code, or series of codes at BOOTUP to let you know if something is not being read correctly.  I have never known one to beep after loading windows and MAME, even if the memory were defective.
OTOH, it's possible the motherboard either is not supplying enough power to the PS/2 connector for the X-arcade - options:
1) Buy X-Arcade USB adapter
2) Buy external +5V Power Supply and carefully wire it into X-arcade
3) Swap motherboard for other brand
or that the motherboard is not polling the PS/2 port fast enough - options:
1) Buy X-arcade USB adapter
2) Swap motherboard for other brand
screaming
  • Registered lUser
« Reply #10 on: March 09, 2004, 10:33:43 am »
   FWIW, try booting up your AthlonXP or P4 computer without your CPU fan connected to it's power and see how long it takes for your mobo to start beeping like a mofo.
/Steve
Tiger-Heli
    • Tiger-Heli
« Reply #11 on: March 09, 2004, 10:38:03 am »
/Steve
But on an older motherboard, it will beep b/c it can no longer find the (fried) XP processor, not b/c it doesn't sense the fan RPM.
A pretty expensive way to troubleshoot.  OTOH, if you need to JUSTIFY an upgrade . . .
Truz
« Reply #12 on: March 09, 2004, 10:45:52 am »
well i just did a playtest with the USB keyboard unplugged and it seemed like it was going good for a while, but then the beep showed up again. Once again the game slows down a bit for about 2 seconds and then kicks right back in normally. Granted the slowdown doesn bring it to a crawl but it is annoying knowing that something isnt quite right.
 ???  hmmmm im stumped on this one, what do you guys suggest i do. Also the x-arcade usb adapter, wouldnt that just be a usb-ps2 adapter? Do they even make those?
Tiger-Heli
    • Tiger-Heli
« Reply #13 on: March 09, 2004, 10:51:07 am »
Well, you've ruled out the USB keyboard conflicting  :)
See what happens with Ghostkey with all buttons mashed, or with the X-Arcade test utility.  That will rule out something with this version of MAME.
I think X-Arcade sells a USB adapter that goes to the 9-pin connector on the unit, not sure of the cost, though.
Truz
« Reply #14 on: March 09, 2004, 11:07:50 am »
well i went and tried out the x-arcade test utility and i found something very interesting.
Whenever i press the button that represents shift (1 button in the second row) it will not allow me to move the joystick. It is like it is get locked for some reason. When mashing all the buttons together everything seemed fine. But when i hit the shift button and the control stick together it goes all haywire. It as if the cancel eachother out or something. Its really weird.
I even mashed down every single button (except shift) and then moved the control stick and it works perfectly.
So basically when shift and the control stick are moved and pressed together it doesnt work.  Sometimes it will register shift , but most of the time it wont register either the stick or shift being pressed.
Pretty weird if you ask me, what do you guys think?
Tiger-Heli
    • Tiger-Heli
« Reply #15 on: March 09, 2004, 11:18:43 am »
Not sure how Shift works (u just mean the button that is mapped to L shift, correct).
Try running MAME and pressing this button and moving your joystick, if it beeps now, then you've found the problem.
Next try re-programming the X-Arcade to assing this button to something other than Shift, re-run the setup, see if the problem goes away.  If so, remap P1B4 in MAME to whatever you changed it to and you should be golden.
Truz
« Reply #16 on: March 09, 2004, 01:18:03 pm »
well i went into mame and tried out to see if pressing the button mapped to left shift and the control stick would cause the beep, but it didnt. They worked fine together while in mame.
But also here is another weird bit of information... when i play games in MAME with my x-arcade i have to turn the num lock off on my usb keyboard or else the control stick wont work and only the buttons will. But if i run the x-arcade test utility i have to have num lock on or else the control stick wont work. Kind of odd if you ask me, maybe it is another clue in "The great beeping motherboard mystery"
Tiger-Heli
    • Tiger-Heli
« Reply #17 on: March 09, 2004, 02:10:25 pm »
Weird, seems like a conflict somewhere, but I'm all out of ideas.
Truz
« Reply #18 on: March 09, 2004, 02:12:26 pm »
i just wanna say thanks alot for all of your help tigerheli, you have been tremendous help. Hopefully i figure this thing out.
TIGER-HELI ROCKS HARD!!!!!!!!
Truz
« Reply #19 on: March 09, 2004, 02:22:04 pm »
well i went and tried to use the x-arcade with ps/2 keyboard plugged into the passport on the x-arcade and i still had the problem with the shift button and the control stick.
Also i am having a problem with mamewah (hehe the probs just keep on coming) everytime i start it up and then try to activate a game it gives a "runtime error 75" and something like file path error... not to sure. So i go into mamewah setup utility and then repoint it to the mame.exe so it can reload all the roms and then it works. But everytime time i restart mamewah it gives me the same error and i have to go back to the setup utility again. Its like mamewah keeps forgetting where the files are or something. Its really annoying as every time i shut down mamewah it and then try to play again later on it wont work until i reload the mame exe into the mamewah setup utility. whats the deal here?
Tiger-Heli
    • Tiger-Heli
« Reply #20 on: March 09, 2004, 02:29:44 pm »
Also i am having a problem with mamewah (hehe the probs just keep on coming) . . .  whats the deal here?
Not surprised about the PS/2 keyboard not affecting anything.
I haven't used MAMEwah, but is there a chance that you have your .ini files or some files in the MAMEwah directory set to read-only - like if you copied them over from a CD.  If so, that would do it.
Truz
« Reply #21 on: March 09, 2004, 11:11:51 pm »
well i decided to reformat the computer for the hell of it (it was in need of it anyway) and it didnt resolve my problem. I still get the problem within the x-arcade test, and the single beep while playing games. Although the slow down does seem drastically improved now it is still there and annoying. Granted it will only happen once while playing a certain game it is annoying that i cannot figure out for the life of me what the hell the problem is. If anyone can help me out here i would greatly appreciate it.
Tiger-Heli
    • Tiger-Heli
« Reply #22 on: March 10, 2004, 07:28:27 am »
I contacted a knowledgeable anonymous source and he replied (in part):
"Remember when I told you that the PS/2 port triggers an interrupt when the keyboard sends data?  If you have enough data being streamed at the cpu it will overflow the buffer (the "beep")  and choke the processor.....especially if it is running something computation heavy on a slow system."
I doubt you will hear this from their tech support, but my guess is the problem is a less than stellar encoder in the X-arcade (my opinion), combined with possibly a slow processor on your PC, and a processor-intensive application (MAME).
To solve it, I would recommend the following options (in cost-benefit) order.
1)  This is technical, but you don't need to understand the physics, (from my keyboard hacks page):
"There are certain keys which send extra commands to the keyboard buffer and should be avoided.  Highlight these non-recommended keys in Gray (for example) as follows:  Direction Arrows (note that both HotRod and X-Arcade avoid these), Windows Menu Key, L Windows GUI, R Windows GUI,  R Ctrl, R Alt, Insert, Home, Page Up, Delete, End, Page Down, PrntScrn, Pause, Keypad Slash, and Keypad Enter.  Details of how I came up with this list are available here.  Most keys send three characters to the keyboard buffer.  These all send five or more."
IF you are using any of these keys with the X-arcade, reprogram it, reprogram MAME to use the re-defined keys, and test it out.
2) If possible, test the X-arcade on a friend's faster machine.  If your problem doesn't appear, you might want to upgrade your processor/memory/OS version, or all of the above.
3)  It might be helpful to dump MAME for a faster and less hungry emulator, such as Calice, Final Burn, or Nebula for the games you mentioned.
4)  You might want to try the USB adapter for the X-arcade, I think it's about $20.00.   (Although I'm somewhat skeptical that this would help).
5)  If you aren't going to use the X-arcade with console systems, it would be possible to re-wire it to use either a KeyWiz (www.groovygamegear.com) or I-PAC/2 or mini-pac (www.ultimarc.com) encoder for around $40.
6)  Live with it or find other favorite games to play (not what you want to hear, I know).
Truz
« Reply #23 on: March 10, 2004, 09:20:17 am »
well the computer that i am having trouble with is a p4 1.3ghz 512 mb ram with a geforce3.
But i tried it on my main pc (p4 3.0c, 1 gig ram, geforce fx 5900 ultra) and i did not run into the beeping problem. I did however have that problem within the x-arcade utility program.
And i went and checked out the keys that were mapped to the x-arcade, and the ones that might be causing problems are CTRL, ALT, and SHIFT. I know you specified the right ctrl, alt, and shift buttons .... but within the utility it only says xctrl, alt, shift without anything specifying left or right.
So i figured ill try and press the right form of the buttons on the keyboard (running through the pass through port) and sure enough the R ctrl, R alt, and R shift registered as the buttons on the x-arcade.
So i will try and remap these to different buttons and than see if that helps any. Thanks for all your help.
Tiger-Heli
    • Tiger-Heli
« Reply #24 on: March 10, 2004, 09:25:38 am »
Sounds like decent hardware in both machines (it might be more a function of how fast the particular mobo polls the PS/2 port), I'm not sure of this, but I should have made that clear.
Remapping buttons is the easiest (and free) thing to test.
Let us know how it turns out.
Truz
« Reply #25 on: March 10, 2004, 01:01:59 pm »
well i went and remapped the buttons, and it was looking good for a little bit. But than the beep  came up again. I was getting excited because it looked like it may have solved my problem but then bam! the beep came again.
I guess we can rule that out as one of the problems
Could the problem be that the PSU isnt supplying enough power? This is my families old HP pavilion (yea i know... hp sucks) and i have added some new components to it from when we first got it. I added a sb live 5.1 card (had some generic crap in there) and i put in a geforce3 64mb in it also (it had a crappy tnt card in it). The psu is only 250w but i would think that would be enough to handle it right? This pc also has a cd burner and a dvd drive as well. Just a thought but maybe a problem. Is there any program or app to test the stressload or what not on the psu.
Tiger-Heli
    • Tiger-Heli
« Reply #26 on: March 10, 2004, 01:25:14 pm »
Maybe, but a psu would usually cause more problems - like this -
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=16976
Nailz
  • Last login:April 23, 2014, 08:55:03 pm
« Reply #27 on: March 10, 2004, 01:39:22 pm »
That is a lot of hardware for a 250W PS, maybe try unhooking one of the cd drives and see if that helps.  Also might not be a bad idea to see if your cpu fan is actually making contact with your cpu.  I had this happen to me recently, no contact between them, the computer was ok until I did something a little more stressful, then it would barf.  I applied a little thermal grease, and no more problems.....
Just one more thing to add to the list.  :)
Truz
« Reply #28 on: March 10, 2004, 01:55:55 pm »
ok, ill try disconnecting the disk drives.... as i dont really use them anyway (i use my ipod to transfer files over) and then i will see what happens. Also i have a pci modem in there that i dont use that i will take out as well.  Ill try this stuff for the hell of it as i am desperate to figure this out as it is really bugging me. I think the fact that i dont know what it is is more annoying that the actual problem... hehe.
Truz
« Reply #29 on: March 10, 2004, 03:04:48 pm »
well i went and disonnected both the cdr drive and the dvd drive from the psu and also removed the pci modem card. And i still received the beep from the motherboard. This really does suck. This is the pc i plan to put in a mame cab in the *hopefully* near future but it will be quite annoying if i get this beep every once in a while.
cdbrown
  • Bowowow
« Reply #30 on: March 11, 2004, 12:39:03 am »
Is it the same buttons being pressed and joystick direction each time the pc beeps.  I just tested on my keyboard and when I press 5 keys at the same time - nothing comes up on the screen and pc beeps.  But you have said before that holding all buttons down (except shift) and moved the joystick and all is fine.  Perhaps the x-arcade encoder is dodgy.  Would be interested to see the default.ini file in the XArcade ctrlr folder (if you have told mame to use that ctrlr file).  That numlock problem is due to the ctrlr file being mapped to
P1_JOYSTICK_UP          "KEYCODE_8_PAD"
P1_JOYSTICK_DOWN        "KEYCODE_2_PAD"
P1_JOYSTICK_LEFT        "KEYCODE_4_PAD"
P1_JOYSTICK_RIGHT       "KEYCODE_6_PAD"
instead of
P1_JOYSTICK_UP          "KEYCODE_UP"
P1_JOYSTICK_DOWN        "KEYCODE_DOWN"
P1_JOYSTICK_LEFT        "KEYCODE_LEFT"
P1_JOYSTICK_RIGHT       "KEYCODE_RIGHT"
Also was this what you were talking about shift before
P1_BUTTON4              "KEYCODE_LSHIFT"
Now that you've remapped do you still get the problem in the xarcade tool regarding one button cancelling out the joystick?
Tiger-Heli
    • Tiger-Heli
« Reply #31 on: March 11, 2004, 07:15:43 am »
That's because modern keyboards are designed to prevent ghosting and won't allow three keys in the same square on the matrix to be pressed.  The encoder in the X-arcade should not have this problem, though.
Perhaps the x-arcade encoder is dodgy.  . . . That numlock problem is due to the ctrlr file being mapped to
instead of
And it is mapped to keycode 8 instead of Keycode Up probably partly b/c (as I said above) the UP Arrow sends more codes to the keyboard buffer, and possibly the X-Arcade encoder can't handle it.
A bit of history, before I get flamed by X-Arcade.  HotRod basically started this with their encoder.  The official story is that it was for compatibility with older programs and older keyboards that did not have separate arrow keys.  But when it was being sold, MAME was it's most common use.  And MAME has always used the arrow keys as default (poor choice, performance wise).  So I suspect the choice of the Numpad keys had more to do with the performance of their encoder.  But since it's non-programmable, there's no real way to test this.  I suspect that X-Arcade selected the NumPad keys mainly to have forward compatibility for people purchasing it to replace a HotRod, but the fact that the NumPad keys provided better performance probably didn't hurt either.
Good question, Truz?
Truz
« Reply #32 on: March 11, 2004, 08:49:55 am »
yes i remmapped the button that was mapped to shift and replaced it with M.
Then i went into the x-arcade utility and i still had the problem with that button and the control stick being pressed at the same time. They are still basically cancelling each other out.
SirPeale
  • Green Mountain Man
« Reply #33 on: March 11, 2004, 09:45:11 am »
One thing you have not mentioned is what motherboard you have.
Your 'specs' are certainly up there - P4, tons of RAM...but a crappy motherboard will be a serious bottleneck.
The two most important pieces of any computers system, in order, are: Power Supply and Motherboard.  Without them, you have a box of parts.
Tiger-Heli
    • Tiger-Heli
« Reply #34 on: March 11, 2004, 09:45:18 am »
I wouldn't think that should be happening.  Maybe it's a wiring problem with the X-Arcade, or with it's encoder (your specific one, not in general).
At this point, I think I'd give their tech support number a call and see what they have to say
Truz
« Reply #35 on: March 11, 2004, 10:18:02 am »
well this pc is an hp pavilion (crap i know), but the motherboard inside is an ASUS P4T.
yea and the problem with the button and the stick cancelling each other out definately should not be happening. But it is weird as it does not happen in mame at all, and only occurs in the x-arcade test utlity.
cdbrown
  • Bowowow
« Reply #36 on: March 11, 2004, 08:28:18 pm »
I would recommend re-mapping every single button and joystick movement to letters only.  Then open up notepad to ensure they are all working right.  Try ghostkey and press any and every combo you can come up with.  Then move onto the x-arcade test utility.  Have you sent x-arcade an email regarding this - they may just come back and say its a bug in the utility '???'.  Then jump into mame and press all the buttons and move the joysticks to see if you can get it to happen.  Try and se if there is a pattern regarding which microswitches are being activates together or if it's just a number of microswitches thing.  The cancelling out after remapping is strange.
Truz
« Reply #37 on: March 12, 2004, 12:33:33 pm »
well i remapped all the buttons and it was not successful. The beep still comes in at a random point. And thats the thing about it, i cannot reproduce the beeping as it is totally random and has no set pattern so it is hard to tell what is causing it.
The weirdes thing  its that i have not experienced this in any other game. I have even looked for it in similar games such as marvel vs streetfigher... but i havent seen it in that game.
Truz
« Reply #38 on: March 16, 2004, 04:07:08 pm »
ok well i have still not figured this problem out and i have tried a lot of things.
I was thinking maybe it is an overheating problem.
So i have MotherBoard Monitor to tell me my temps. The temps it gives me after the beep occurs are 84 degrees farenheit for the case temp and 82 for the cpu temp. Are these too high? Also when idle in desktop the cpu temp levels off to about 77-78 degrees. Are these temps to high i dont really know what it too hot.
Also maybe it is a overheating gfx card problem. I placed my hand on the card (geforce3) and it seemed a bit warm. Anyone know how i can check the temp of the gfx card.
I still cant believe i have not yet fixed this oh so annoying problem.
Nailz
« Reply #39 on: March 16, 2004, 04:50:00 pm »
Umm, yeah, that's way too high.  Did you ever try what I suggested earlier, and put some thermal grease on your CPU so you will have better contact between the cpu and the fan?
