Author Topic: Megatouch ML-1 w/ Cracked Touch Overlay & Front Bezel - Am I Hopeless?  (Read 7511 times)
ekimshaff
  • Last login:November 01, 2024, 10:40:17 am
Hello,
I picked up an ML-1 that is working but was hit in the front corner and has a cracked, yet working, touchscreen overlay and front bezel.  Machine still works and LCD is fine.
Does anyone have replacement parts for sale or perhaps know of a way to use a different overlay for this machine?  If worse came to worse maybe I could 3D print a serviceable replacement bezel but I don't know what to do about the touch overlay.  I'm located in MN.
Megatouchmike
  • Last login:September 19, 2025, 01:43:48 pm
Re: Megatouch ML-1 w/ Cracked Touch Overlay & Front Bezel - Am I Hopeless?
« Reply #1 on: November 02, 2024, 11:27:52 am »
Not sure if front or rear bezel is cracked but ami still sells the rear
https://parts.amientertainment.net/Products/Games/BZL-MON-REAR-ML-1.html
As far as the touch glass, someone bought them all up from AMI and is either hoarding or reselling. So they are pretty much unavailable now
If you are able to find any other manufacturer touchscreen that fits, I can help you with getting it to work
