Author Topic: Help with installing a simple coin acceptor  (Read 6583 times)
Nitro0602
  • Last login:July 26, 2025, 11:44:11 am
« on: October 22, 2024, 04:52:57 pm »
Hey guys! I just want to install a simple coin acceptor on my pi for fun. Is there any model that works best and easy to setup. Sample picture and link below of what I was thinking. I heard some of them can just plug directly into the arcade encoder.
https://a.co/d/6RKBeq1
  • Last login:Today at 05:55:39 pm
Re: Help with installing a simple coin acceptor
« Reply #1 on: October 22, 2024, 05:19:51 pm »
Coin mechs that can connect directly to an arcade encoder are the ones that use a microswitch.
Electronic coin acceptors like the one you linked to run off 12v.
You need a 5v Zener diode to bring the 12v signal from the acceptor down to 5v for the encoder.
Nitro0602
« Reply #2 on: October 22, 2024, 07:09:14 pm »
Thanks Scott! Is there any models like the pic attached that have a microswitch?
« Reply #3 on: October 22, 2024, 10:37:32 pm »
Disclaimer: I haven't done an in-depth search, so there may be a coin mech model that I've overlooked.   :dunno
- A helpful search term is "coin mech" (maybe a microswitch model) instead of "coin acceptor". (definitely a powered model)
AFAIK the closest to the pic you posted would probably be one of these Nintendo coin mechs.
- If you don't like the Nintendo-style look, you might be able to mod one of those coin acceptors by adding a wire arm microswitch.
Nintendo Style Coin Mech - https://www.arcadeshop.com/i/1212/nintendo-coin-mech.htm
Asahi Seiko 730-A - https://www.mikesarcade.com/cgi-bin/store.pl?sku=TKG-01-03
Asahi Seiko KWM-740 - https://www.mikesarcade.com/cgi-bin/store.pl?sku=TKGU-01-02
Asahi Seiko 900-F37 - https://www.mikesarcade.com/cgi-bin/store.pl?sku=900-F37
If you have access to a 3d printer, you can print something like one of these models or design your own.
https://www.thingiverse.com/thing:4422904
https://www.thingiverse.com/thing:4243087
