Author Topic: Question of testing Arcade Buttons  (Read 1999 times)
MrInitialMan
  • Last login:January 04, 2025, 05:09:33 am
  • A writer desperate to avoid plotholes
    • Mr. Initial Man's Den
« on: September 06, 2024, 05:37:54 am »
Is using an arcade button as a low-voltage/amperage light switch (Say, using a AA battery as a power source with an appropriate lightbulb) a sufficient way to test it?
RandyT
  • Last login:September 13, 2025, 08:12:16 am
    • GroovyGameGear.com
Re: Question of testing Arcade Buttons
« Reply #1 on: September 06, 2024, 10:37:54 am »
If you want a non-computer related way to test the button (switch), sure.  You could just find an LED with a forward voltage of more than 1.5v and wire it direct to the AA battery.  But just as easy would be to pick up a low-cost multimeter with a continuity beep option.  Then you would have the proper tool for all kinds of electrical troubleshooting in the future as well.
MrInitialMan
« Reply #2 on: September 06, 2024, 02:04:56 pm »
I ask because I'm writing a story, and in one particular scene a youngster is JUST starting out in cabinet repair.  Thank you for your answer.  :)
mrbones
  • Last login:September 19, 2024, 12:25:11 pm
    • ATVFlorida.com
« Reply #3 on: September 16, 2024, 05:29:51 pm »
Very interesting. Yep. That would do it.
