Author Topic: KTN-2001 using GroovyArcade sync issue?  (Read 2091 times)
sk8ersublime
  • Last login:October 23, 2025, 11:13:39 pm
« on: August 30, 2024, 02:59:11 pm »
Hi
I was just trying to see if anyone else has had an issue with using a Kortek KTN-2001 monitor in a cabinet using a PC and GroovyArcade.
I can use the same setup with a K4900 and a K7000 and it works fine, but on both KTN-2001 monitors it will not sync.
I can use the same VGA breakout cable with a Raspberry Pi and the KTN-2001 works perfectly. I’m so confused haha. Any advice would be great.
Thank you!
Substring
  • Last login:November 23, 2025, 01:16:00 pm
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
Re: KTN-2001 using GroovyArcade sync issue?
« Reply #1 on: October 03, 2024, 12:32:08 pm »
Got some data on that monitor ? Saying it works with the Pi is not just enough. Better gives us the working modeline if you have it, thanks.
