Author Topic: Created a CRT/LCD combo type monitor.  (Read 2185 times)
psiomicron
  • Last login:November 04, 2024, 09:47:06 pm
« on: August 03, 2024, 02:49:24 pm »
In someway I'm a CRT purist when it comes to coin op arcade games (and old consoles as well). However, I have found it very time consuming and expensive to either fix or replace 25 inch CRTs in my arcade cab. I have found a happy medium. I have created a CRT lens and combined it with an LCD screen. Along with running the proper CRT shader it comes extremely close to a real CRT. I made a mold of a 25 inch crt screen and then casted the screen out of epoxy. After sanding and polishing I combined it with an LCD that fit close to the dimension. See pics and video example in the link below.
See link for more pictures and video of the project:
https://imgur.com/a/KVkXHkG
« Last Edit: September 20, 2024, 01:04:47 pm by psiomicron »
Rocketeer2001
  • Last login:December 30, 2024, 01:35:31 am
  • Working on Arcades and drinking Lemonade
Re: Created a CRT/LCD combo type monitor.
« Reply #1 on: August 05, 2024, 01:43:55 pm »
Nice! Maximum effort!
Curious, why didn't you vacuum form or heat form a piece of acrylic over the mold instead of pouring resin and sanding/polishing?
psiomicron
« Reply #2 on: August 05, 2024, 04:21:44 pm »
If I use an acrylic sheet for the screen it wouldn't bend the light as it should, it needs to be a solid lens. It would be like putting a tupperware bowl over the screen, just be a plastic window on the screen and wouldnt look like a CRT should. Now if you meat why didnt I use an acrylic sheet for a mold of the origional CRT then cast an epoxy lens from that... because I wanted to be able to cast multiple lenses, protoypes, back ups, etc. and didn't know how many I could cast using and acrylic mold vs silicon. Silicon I was able to make multiple. I may try the vacuum forming as molds later for different CRT sizes.
