Author Topic: Megatouch Force 2004.5 Hard drive clone  (Read 7781 times)
Driftek
  • Last login:November 01, 2024, 07:52:10 pm
« on: July 30, 2024, 05:48:53 pm »
I cloned the old IDE drive inside of my model: KOV-105-104 Merit mega touch to a SSD and used a converter with the jumper set to master to boot the drive using the IDE cable. I verified that the serial numbers match after the clone. It boots up, but it tells me that my key is invalid for the software. If I put the old IDE drive in then it makes it past the key check. Is the hardware key locked to a hard drive? What am I missing here?
« Last Edit: July 30, 2024, 06:38:41 pm by Driftek »
Megatouchmike
  • Last login:September 19, 2025, 01:43:48 pm
Re: Megatouch Force 2004.5 Hard drive clone
« Reply #1 on: July 30, 2024, 10:32:48 pm »
The key isn't locked to a drive, but there is a hard drive model check in Force 2004.  The game reads the model from /proc/ide/ide0/hda/model, so it's easy to bypass.
Adding something like this in a boot script should do the trick:
Code: [Select]
echo MERIT0011 > /tmp/hd
mount -n -o bind /tmp/hd /proc/ide/ide0/hda/model
« Last Edit: July 30, 2024, 10:39:32 pm by Megatouchmike »
Driftek
« Reply #2 on: July 31, 2024, 05:30:03 pm »
Thank you! I’ll give that a shot
Driftek
« Reply #3 on: July 31, 2024, 06:10:18 pm »
Code: [Select]
That did the trick! Thank you.
lilshawn
  • Moderator
  • Last login:March 01, 2026, 06:22:50 pm
« Reply #4 on: August 04, 2024, 02:32:02 pm »
the "merit0011" custom hard drive model check was removed beginning with the 2005 software year. the installer software will complain of a non-merit drive being installed (buy a merit drive for reliability and performance and whatnots message) but will still install after a short delay of displaying the message.
