Author Topic: Can't adjust 640x480 modeline  (Read 4792 times)
Endprodukt
  • Last login:Yesterday at 08:29:29 am
« on: July 24, 2024, 05:11:20 pm »
I'm very aware you can't edit the desktop resolution. But 640x480 isn't my desktop resolution.
Everything else is fine in my setup but that one mode needs adjustments. No idea why it's not working.
Any help appreciated.
Endprodukt
Re: Can't adjust 640x480 modeline
« Reply #1 on: August 02, 2024, 12:48:47 am »
Still no solution. Anyone?
I'm using Windows 7.
Zebidee
  • Trade Count: (+9)
  • Last login:Yesterday at 11:11:48 pm
« Reply #2 on: August 02, 2024, 01:07:34 pm »
There is a Windows "native" 640x480 mode at 60p (non-interlaced) which you cannot edit - it is hardware locked. You'll only see it in ArcadeOSD if you have "Lock unsupported modes [no]" selected on the first ArcadeOSD screen. Normally you should select "[yes]" there.
All that's assuming you're actually using CRT_emulator and ArcadeOSD on a CRT. Maybe provide some more detail and/or screenshots. What monitor, graphics card you are using, what you've tried to do (and how, why). People won't respond if they are not sure exactly what your issue is.
Endprodukt
« Reply #3 on: August 02, 2024, 05:58:59 pm »
Well then that's that. The native mode.
Using a Hantarex Polo Star Trisync. So I guess that means getting the native 480p set first and then everything else. Let's see when I feel like starting over.
Zebidee
  • Trade Count: (+9)
« Reply #4 on: August 02, 2024, 08:56:25 pm »
The "native" mode is locked into the driver, you cannot edit it.
Maybe try creating a "custom" mode for something close, like 648x480p or 640x480p@59hz
CRTFTW
  • Last login:December 02, 2025, 02:23:08 pm
« Reply #5 on: August 04, 2024, 04:35:01 pm »
For 480p, you can delete the default mode with CRU, then make a custom 480p mode that the driver should default to
Endprodukt
« Reply #6 on: August 04, 2024, 05:04:20 pm »
Does that work in win 7?
CRTFTW
« Reply #7 on: August 10, 2024, 04:19:11 pm »
I can't think of any conceivable reason to be on Win 7. You can use your Win 7 key to upgrade to Win 11 for free
Zebidee
  • Trade Count: (+9)
« Reply #8 on: August 10, 2024, 09:17:02 pm »
There's a few good reasons someone might not want to upgrade their arcade PC from Win 7 to Win 11, but that's not really important and I'm not looking for an argument today.
Ever wonder why Microsoft skipped a number with their Windows releases? It is quite simple when you think about it.
Seven eight nine!   :scared
« Last Edit: August 10, 2024, 09:18:33 pm by Zebidee »
Endprodukt
« Reply #9 on: August 18, 2024, 02:08:10 am »
VMM not working.
haynor666
  • Last login:November 21, 2025, 05:45:00 pm
  • retro maniac
« Reply #10 on: August 27, 2024, 04:58:45 am »
In my case it was not possible because it was in use by system. I switch to other resolution and them 640x480 was editable.
