Author Topic: x360ce Stop Constantly Having To Reconfigure Device  (Read 3495 times)
Yardley
  • Last login:July 22, 2025, 11:36:15 pm
« on: May 08, 2024, 11:04:11 am »
I am using x360ce with a Logitech G29 to emulate an Xinput controller. Under the "Controller 1" tab, I click on the plus "Add" button and select my wheel from the list with the green square to the left which means it is active. I then map everything to my liking and click "Save All". All is well and works as intended, however, this config is lost after reboots and/or unplugging and plugging my G29 back into my PC. It never remains stable and I have to go in and do this process all over again.
Each time I click on the "Add" button, I see different instances of the G29 each with a different Instance ID, they always have a grey square next to them except one of them which is the one I have to select and reconfigure each time. Back in the "Controller 1" tab, I can also see different instances of the G29 and they all have a different "Setting ID" and "Instance ID" but only the latest one I added will have a green square next to it and obviously will be the only that works.
What I'm I missing here? How do I keep from having to constantly reconfigure my G29?
nugarp
  • Last login:November 09, 2025, 11:22:06 pm
Wheel2XInput | HDRecoil | LeaderLamps | NetLauncher | Discord | Youtube
Yardley
Re: x360ce Stop Constantly Having To Reconfigure Device
« Reply #2 on: May 08, 2024, 11:54:03 pm »
Use better software :) https://forum.arcadecontrols.com/index.php/topic,166939.0.html
G29 config - https://forum.arcadecontrols.com/index.php/topic,166939.msg1767038.html#msg1767038
Haha, yeah I've posted on your thread before. I have to finally give w2x a try. Does w2x have issues with GUID's changing after reboots or from plugging/unplugging a wheel or if I use a different G29 wheel (I have 2). In other words, If I configure my G29 will I have to constantly update the GUID in the config files when Windows inevitably changes it?
I've been testing UCR and it works great and doesn't have this issue, I configured my wheel once and I've never had to do it again. Problem is it doesn't seem to support rumble/FFB. For example, I was testing the game New Star GP and with x360ce, I get FFB but with UCR I don't.
nugarp
« Reply #3 on: May 09, 2024, 06:21:10 pm »
Set it once in the config and forget it. It is already set in the g29 files.
