Author Topic: CRT tv has vertical scroll only at288 resolution at 51hz.  (Read 355 times)
Dorthensensens
  • Last login:May 28, 2024, 10:49:11 pm
« on: April 21, 2024, 11:34:00 pm »
One of my crts cannot play games like Pac-Man when switchres tries to use anythingx288 for resolution without having a scrolling sync problem. It’s only on my 20” tv. Is there a way I can force the resolution to use something else?  Or is there some other solution that would be better?  Thank you
pakoman
  • Last login:May 20, 2024, 06:11:32 pm
Re: CRT tv has vertical scroll only at288 resolution at 51hz.
« Reply #1 on: April 22, 2024, 09:55:57 am »
Maybe you can use 280 lines and crop 4 lines up and down ?
Would increase the hz too.
Or as it seems you have several screens, why not rotating the TV and use the native resolution for vertical games?
Dorthensensens
« Reply #2 on: April 22, 2024, 10:37:19 am »
Thank you for the reply. When you say to crop some of the lines, are you referring to changing crt emu driver settings?  I was playing around with the monitor defaults but I’m afraid of breaking things. Any advice on how to properly do so will be appreciated.
And yes if I turn it side ways it works perfectly except this tv is in a fixed arcade cabinet running multiple duties to play various landscape and portrait games. Donkey kong for example works fine. It’s only resolutions like Pac-Man that cause me an issue on that specific tv.
